Center Cap Sizes
pjf1985
Just a quick question regarding center cap sizes. Am I correct in thinking if the center bore of some wheels are the same, the center caps should fit both wheels?
Just wondering as I'm not sure on whether to get center caps with some aftermarket wheels or just use the ones I have on my Rays (or get Z ones) if they would fit?
Cheers :)
If your new wheels have a 66.1mm centre bore (same as a Zed) then you can re-use the caps.
If your new wheels require spigot rings to be fitted, you'll need new centre caps (normally provided with new wheels).
  • 8 months later...
