SkylineV35 Posted May 13, 2014 Share Posted May 13, 2014 I ordered a Competition stage 2 clutch 1month ago via Clark Motorsport, did the whole bedding in procedure 500 miles then adjust after 750 miles etc. The mechanic that fitted it was the same one that fitted my exedy stage 1 which lasted a year bare in mind 13000 miles. Im sure iv only done about 3000miles and the clutch biting point is basically gone, clutch is slipping I havent even been on track or driven it hard yet?! Is there anything that iv not done? iv checked over the instructions and everything was done. for the first 3weeks biting point was fine if not a little juddery. which is supposed to go away after a while but instead of it going away my biting point is almost a brake level!? Iv read up on other forums having problem with this particular stage2 clutch, has anyone else had this problem or could shed some light on the situation? Thanks Saskhi Quote Link to comment Share on other sites More sharing options...
glrnet Posted May 13, 2014 Share Posted May 13, 2014 Firstly, I should PM Ewen (he's a decent bloke) at Clark Motorsport and ask him about warranty and known issues, secondly, did you change the flywheel at the same time, thirdly, unless you've been tracking 13000 isn't a lot on an Exedy Stage 1 TBH. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted May 13, 2014 Share Posted May 13, 2014 Have you got 1500BHP you didn't know about ? 4 Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted May 13, 2014 Share Posted May 13, 2014 I'd say change the mechanic if your old one only lasted that long too then i dont think he's doing it right lol! 13k on a stage 1 is nothing either, also as above im changing mine as we speak and have changed the flywheel to as suggested when doing the clutch as them dual mass thingy's are a bit dodgy! Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted May 13, 2014 Author Share Posted May 13, 2014 Flywheel was resurfaced, the stage1 I had before I was fecking around alot with it. But this one i havent even wheelspun it once lol Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted May 13, 2014 Share Posted May 13, 2014 Do you still have the dual mass? Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted May 13, 2014 Share Posted May 13, 2014 maybe the pedals been adjusted wrong and its not completely disengaging the clutch causing it to slip. have you tried adjusting the pedal back? Quote Link to comment Share on other sites More sharing options...
Ricey Posted May 13, 2014 Share Posted May 13, 2014 Being totally honest was the flywheel resurfaced properly? Quote Link to comment Share on other sites More sharing options...
wizurd Posted May 13, 2014 Share Posted May 13, 2014 Jesus I didn't expect to see this post considering how fast you went through the stage 1 mate! Got to be something wrong for it to fail this early unless it is something like pedal adjustment or the flywheel? Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted May 13, 2014 Share Posted May 13, 2014 Sounds like you have an issue somewhere else in the system to wear out 2 clutches that quick. Far to quick.... Unless your on the strip. Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted May 14, 2014 Author Share Posted May 14, 2014 Sorry guys im such an idiot! Iv been adjusting the pedal wrong.. the rod is supposed to come out towards you not in, hence why when i adjusted it the biting point went higher, to the point where it was near the top of the clutch pedal travel and wasnt fully engaging hence slippage. She fine now but feels very oem rather than stage2 though as before it was rather bite or stall with it. 1 Quote Link to comment Share on other sites More sharing options...
Zhorno Posted May 14, 2014 Share Posted May 14, 2014 Sorry guys im such an idiot! Iv been adjusting the pedal wrong.. the rod is supposed to come out towards you not in, hence why when i adjusted it the biting point went higher, to the point where it was near the top of the clutch pedal travel and wasnt fully engaging hence slippage. She fine now but feels very oem rather than stage2 though as before it was rather bite or stall with it. 😂 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ioneabee Posted May 14, 2014 Share Posted May 14, 2014 doh Quote Link to comment Share on other sites More sharing options...
glrnet Posted May 14, 2014 Share Posted May 14, 2014 At least you admitted your mistake, hope it's all ok now? Sent from my Zed using Nangkang tyres front, RE040's rear Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted May 14, 2014 Author Share Posted May 14, 2014 Yup shes fine now.. better a mistake than a new clutch lol 1 Quote Link to comment Share on other sites More sharing options...
Keyser Posted May 14, 2014 Share Posted May 14, 2014 Still beat my record - 19,000 on a JWT clutch Gonna sulk for days now 2 Quote Link to comment Share on other sites More sharing options...
wizurd Posted May 14, 2014 Share Posted May 14, 2014 (edited) Nice one mate, at least you found the reason for it and it was simple Edited May 14, 2014 by wizurd 1 Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted May 29, 2014 Share Posted May 29, 2014 I love "doh" mistakes, far cheaper than mechanical ones. Good stuff. Quote Link to comment Share on other sites More sharing options...
