Kerry Posted May 12, 2014 Share Posted May 12, 2014 Hi guys I fitted an aux lean to my Bose headunit using the hack guide and it worked great. However a friend of mine was trying to eject a cd and pressed the cassette eject button now the tape deck display just says eject tape but there is nothing in there to eject how do I fix this? Do I need to put a cassette in the cassette deck? Quote Link to comment Share on other sites More sharing options...
Watshot Posted May 12, 2014 Share Posted May 12, 2014 I can't remember exactly, but I think you just need to do the reset detailed in the guide. Or remove the battery, then do a reset... Quote Link to comment Share on other sites More sharing options...
cs2000 Posted May 12, 2014 Share Posted May 12, 2014 Correct, just follow the reset sequence in the guide. Will probably take you 4 or 5 tries as timing is VERY important with it. Quote Link to comment Share on other sites More sharing options...
Kerry Posted May 12, 2014 Author Share Posted May 12, 2014 Ok cheers guys I'll take a look today thanks Quote Link to comment Share on other sites More sharing options...
Kerry Posted June 10, 2014 Author Share Posted June 10, 2014 Hi guys I tried the reset I found on the how to page ie turn on ignition let head unit start up then turn off remove key and hold cassette eject for 60secs then turn ignition back on but still no luck, any other ideas? Not having my own music in the car is driving me mad lol Quote Link to comment Share on other sites More sharing options...
Hooch Posted June 10, 2014 Share Posted June 10, 2014 I gave up. Get a tape, remove all the actual tape from it and put it in. No problem. I use a cheap Bluetooth adaptor and its great. Check out the last few pages on the Bose hack guide in the guide section. Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted June 10, 2014 Share Posted June 10, 2014 You should be able to poke the cassette loader in place with a biro 1 Quote Link to comment Share on other sites More sharing options...
aidan Posted June 10, 2014 Share Posted June 10, 2014 Hi guys I tried the reset I found on the how to page ie turn on ignition let head unit start up then turn off remove key and hold cassette eject for 60secs then turn ignition back on but still no luck, any other ideas? Not having my own music in the car is driving me mad lol Keep trying....it does work. Took me a few goes. As stated , timing needs to be spot on. Quote Link to comment Share on other sites More sharing options...
Kerry Posted June 10, 2014 Author Share Posted June 10, 2014 Cheers guys I'll give that ago Quote Link to comment Share on other sites More sharing options...
Kerry Posted June 10, 2014 Author Share Posted June 10, 2014 Had a play with trying the reset again today no luck so I had a poke about with a brio in there and couldn't get anything to move so I took a cassette with no tape in and I wouldn't quite go in all the way and I can't eject it so I've managed to get the cassette stuck in there now aswell lol. Think I need to take it all apart again. Any advise on what to do with the tape deck once I get it apart? Should I just get the cassette back out and keep trying the reset? Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted June 10, 2014 Share Posted June 10, 2014 I would take it apart again, sounds like something is not correct. The Cassette mechanism should move freely with or without a cassette in. Quote Link to comment Share on other sites More sharing options...
Hooch Posted June 10, 2014 Share Posted June 10, 2014 Yup. I left everything as it was except soldering on the wires. Tape should insert and eject fine so does sound like something's not right. Quote Link to comment Share on other sites More sharing options...
Jimbo Mahoney Posted June 10, 2014 Share Posted June 10, 2014 Heya, I had this problem too, but the reset procedure worked great. It's important to follow exactly: turn the ignition off and remove the keys. Hold the tape eject button for 60 seconds. release the button and turn the ignition on again. select "tape" and attach a device for test. At first, I was stumped because I hadn't removed the keys / turned off the ignition. After I held the button in with the keys removed, then inserted the keys and turned on, the deck went through some kind of start-up routine and no longer needed a tape inserted. Hope this helps! Quote Link to comment Share on other sites More sharing options...
PageyUK Posted June 10, 2014 Share Posted June 10, 2014 Heya, I had this problem too, but the reset procedure worked great. It's important to follow exactly: turn the ignition off and remove the keys. Hold the tape eject button for 60 seconds. release the button and turn the ignition on again. select "tape" and attach a device for test. At first, I was stumped because I hadn't removed the keys / turned off the ignition. After I held the button in with the keys removed, then inserted the keys and turned on, the deck went through some kind of start-up routine and no longer needed a tape inserted. Hope this helps! Did you need to cut the tracks Jumbo? Sent from my HTC One using Tapatalk Quote Link to comment Share on other sites More sharing options...
Hooch Posted June 10, 2014 Share Posted June 10, 2014 You don't need to cut the tracks, that was done in an attempt to reduce noise. Quote Link to comment Share on other sites More sharing options...
Kerry Posted June 10, 2014 Author Share Posted June 10, 2014 Ok managed to remove the cassette and finally got the reset to work all seems to be working fine now cheers for all your help guys appreciate it. 1 Quote Link to comment Share on other sites More sharing options...
