Wiper arms seem loose?
torino
Hi there, had a bit of a search, but couldn't come up with the answer, but apologies if its been covered before. Seem to have a small problem with the wipers and wondered if anyone else has experienced this - The wipers seem to have movement in them, and they seem to hit the deck as they return down, or run past the windscreen. Hard to explain, but you can move the wipers a few inches by hand, they seem to have a bit of slack somewhere??
Just reposition the wipers and retighten the nuts at the base of the wiper arms as they may have worked loose.
Failing that you may have a worn mechanism
Alex. :)
Edited by ZMANALEX
Sorry, completely missed your reply's.
Sounds like worn mechanism then, as moving one, moves the other, ie they are connected 'together' tightly, but is slack between the arms and motor. Wondered if it was a common problem, but doesn't sound like it is.
Thanks,
