TDI Posted August 1, 2007 Author Share Posted August 1, 2007 Cosworth tri metal race engine bearings withstand greater loads and last longer than standard Quote Link to comment Share on other sites More sharing options...
TDI Posted August 1, 2007 Author Share Posted August 1, 2007 Crankshaft in situ showing the Cosworth studs Quote Link to comment Share on other sites More sharing options...
TDI Posted August 1, 2007 Author Share Posted August 1, 2007 With main caps/stud girdle installed Quote Link to comment Share on other sites More sharing options...
TDI Posted August 1, 2007 Author Share Posted August 1, 2007 ...and again Quote Link to comment Share on other sites More sharing options...
TDI Posted August 1, 2007 Author Share Posted August 1, 2007 We use a special dummy cylinder head when boring/honing the block to pull everything into line prior to the machining process. This is the block assembly fitted with crankshaft, pistons and rods, and showing the Cosworth head studs Quote Link to comment Share on other sites More sharing options...
TDI Posted August 1, 2007 Author Share Posted August 1, 2007 Oops - run out of Upload quota Quote Link to comment Share on other sites More sharing options...
TDI Posted August 1, 2007 Author Share Posted August 1, 2007 The pistons crowns showed a remarkable amount of carbon deposits for such a low mileage engine Any particular reason for this? Running on 95 RON or something, just poor quality fuel etc? Hi Jacko, we found out that the cylinder bores were slightly oval which causes an inconsistant piston ring seal Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 1, 2007 Share Posted August 1, 2007 would this be a common problem Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 would this be a common problem This is the 2nd engine we have seen so far with this issue Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 Both cylinder heads installed Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 From a slightly different angle Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 Water pump installed Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 Oil pump installed Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 Camshafts, inlet manifold and valve covers installed Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 Timing chain installed Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 Camshaft sprocket and variable timing assembly Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 We like to add little "finishing touches" like this special treatment to some of the metal components. The cost is disproprtional to the value - it only costs a few Pounds to do but it looks a "million dollars" so is well worth the effort Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 2, 2007 Share Posted August 2, 2007 would this be a common problem This is the 2nd engine we have seen so far with this issue On Behalf of H5 What are the implications are of those deposits in the engine over time? Cheers, Rob. Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 would this be a common problem This is the 2nd engine we have seen so far with this issue On Behalf of H5 What are the implications are of those deposits in the engine over time? Cheers, Rob. Hi Rob, the carbon build up is the result of oil consumption, and can ultimately lead to an increase in compression ratio and "hot spots" in the combustion chambers - which can cause detonation. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 2, 2007 Share Posted August 2, 2007 would this be a common problem This is the 2nd engine we have seen so far with this issue On Behalf of H5 What are the implications are of those deposits in the engine over time? Cheers, Rob. Hi Rob, the carbon build up is the result of oil consumption, and can ultimately lead to an increase in compression ratio and "hot spots" in the combustion chambers - which can cause detonation. further question from Rob here http://www.350z-uk.com/forum/viewtopic ... highlight= thanks Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 Larger fuel injectors installed Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 APS exhaust manifold Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 Turbocharger assembly Quote Link to comment Share on other sites More sharing options...
TDI Posted August 2, 2007 Author Share Posted August 2, 2007 Turbochargers loosely installed Quote Link to comment Share on other sites More sharing options...
