Compression arm bushings
jimmykool111
Got the knocking noise on the front end (only at low speed). After looking around iv'e come to the decision to change the compression arm bushing first to see if it is that.
I would rather go for a better bushing and have seen the Whiteline ones... anyone on here recommend them? My only problem is i'm unsure what bushings i need to buy because on the website they don't use the word compression arm... am i right in thinking that it is also called a control arm and if so is it upper or lower?
This is the website i used.
http://www.whiteline.com.au/do_segue4.php?make=NISSAN&model=350Z&model_final=350Z+Z33&vehicle=10%2F2003-2009
Thanks!
