AJRFulton Posted May 5, 2014 Share Posted May 5, 2014 Has anyone else had a problem heater system dials. Not sure exactly how they work, but I'm guessing since both dials are displaying the same fault, it's a software problem. I turn the dials, and the display goes as if it is hanging. The temperature/speed then drops 1 unit, and seems to hang... then goes back to where it was. You can turn the dial 100 times and it might only drop/climb 1 fan speed, or 0.5*c. All the switches appear to work correctly, apart from Auto. Which doesn't seem to work at all. Getting a bit tired of issues with my 370Z. For a new car it's been into the garage far too many times for my liking. Brilliant car, let down by disappointing build quality Quote Link to comment Share on other sites More sharing options...
flyboy Posted May 5, 2014 Share Posted May 5, 2014 Had mine stop working altogether on its first long drive since I got it. Nothing worked on the controls and the heater part of the display locked. AC light on but no AC. Stopped at the services and turned off for a few mins and restarted. All ok and not happened again. Would have thought software too. Quote Link to comment Share on other sites More sharing options...
AJRFulton Posted May 5, 2014 Author Share Posted May 5, 2014 Off an back on isn't working. It's still doing. As said it's as if the screen hangs, rather than the switch doesn't work. Quote Link to comment Share on other sites More sharing options...
