torino Posted May 4, 2014 Share Posted May 4, 2014 Hi there, quite new to the 350z, needed new front discs, so bought some off evilbay! They were confirmed as being for the Brembo brake set up, and although they are the correct diameter and stud pattern, the thickness is only just over 20mm!! Anyone know what these are for? Am I right in thinking the JDM brembo's should be 324mm dia and 30mm thick? Thanks in advance.... Quote Link to comment Share on other sites More sharing options...
rothers2901 Posted May 5, 2014 Share Posted May 5, 2014 (edited) FRONT DISC BRAKE (CLZ25VD TYPE) Non Brembo Standard thickness : 24.0 mm (0.945 in) 294mm diameter Wear limit : 22.0 mm (0.866 in) Maximum uneven wear (measured at 8 positions) : 0.015 mm (0.0006 in) or less FRONT DISC BRAKE (OPB27VA TYPE) Brembo Standard Standard thickness : 30.0 mm (1.181 in) 324mm diameter Wear limit : 28.4 mm (1.118 in) Maximum uneven wear (measured at 8 positions) : 0.015 mm (0.0006 in) or less So if the disc have thickness of a little over 20mm then there are neither of the above. Why not buy from one of the many traders on the forum? you are sure to get the correct parts. Don't try and save a few pound when the things you are buying are there to keep you on the road. There is a great deal on at the moment http://www.350z-uk.com/topic/84325-introducing-the-new-dba-t2-disc-for-350z-199-per-pair/ Tyres + Brakes = Spend your money. Information taken from the Nissan 350z workshop manual. Edited May 5, 2014 by rothers2901 Quote Link to comment Share on other sites More sharing options...
glrnet Posted May 5, 2014 Share Posted May 5, 2014 Nice one Martin Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted May 5, 2014 Share Posted May 5, 2014 Good info there Martin If the OP is looking for a more wallet friendly setup then the Pagids we sell are a very popular choice http://www.350z-uk.com/topic/79142-pagid-brembo-discs-for-350z-230-for-front-and-rear-delivered/ Quote Link to comment Share on other sites More sharing options...
torino Posted May 5, 2014 Author Share Posted May 5, 2014 Yeah, definitely the way to go, getting sick of eBay traders. Still doesn't answer what the discs are for though, strange one that! Wonder if they're for a different Nissan! Quote Link to comment Share on other sites More sharing options...
torino Posted May 5, 2014 Author Share Posted May 5, 2014 Think the discs I have are 322mm x 22mm thick with Nissan 5 stud pattern. They weren't the correct discs for the boxes as the part no. on the box should be correct! Quote Link to comment Share on other sites More sharing options...
torino Posted May 10, 2014 Author Share Posted May 10, 2014 Well, not to worry, seller returned my money without even a quibble, even paid the return postage, still no idea what the disc were meant to be for! Now to get some from somewhere I can trust!! Quote Link to comment Share on other sites More sharing options...
