Kev Posted May 3, 2014 Share Posted May 3, 2014 My roadster roof is getting stuck in this position. Any advice would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted May 3, 2014 Share Posted May 3, 2014 (edited) This is common , the roof fabric don't like cold temps so all you need to do to test if it's just that problem is close the roof put the car heaters on full cover the roof with a cover to help heat the roof up faster, then give it a go again,,, you can also uses some clear grease on the roofs frame , this should sort it out ,,, Hope it helps and what ever you do don't take it nissan they will say the hole roof has to be changed they are STUPED !!! And forgot to say if it's not being used for a long time the fabric/ vinyl gets tuff this happened to me when I got my car Sent from my iPad using Tapatalk Edited May 3, 2014 by Briggsybriggs1 1 Quote Link to comment Share on other sites More sharing options...
Kev Posted May 3, 2014 Author Share Posted May 3, 2014 Cheers mate. I'll give it a try. Quote Link to comment Share on other sites More sharing options...
Will370z Posted May 3, 2014 Share Posted May 3, 2014 Yup common problem. Lube up the joints but don't force it down, just keep trying Quote Link to comment Share on other sites More sharing options...
Kev Posted May 4, 2014 Author Share Posted May 4, 2014 Tried leaving the heater on for a hour today. Still wouldn't come down fully Can anyone recommend somebody that knows their way around a roadster roof in the Manchester area? Thanks. Quote Link to comment Share on other sites More sharing options...
Will370z Posted May 4, 2014 Share Posted May 4, 2014 It may be worth contacting sly at kaizer motors on the forum, he knows everything about zeds and we were discussing issues with the 350z roof. 1 Quote Link to comment Share on other sites More sharing options...
Floydbax Posted May 4, 2014 Share Posted May 4, 2014 Mine did this after not being opened for a while, I just worked it back and to on the switch until it eventually went down all the way of its own accord, been OK ever since! Quote Link to comment Share on other sites More sharing options...
Kev Posted May 4, 2014 Author Share Posted May 4, 2014 Mine did this after not being opened for a while, I just worked it back and to on the switch until it eventually went down all the way of its own accord, been OK ever since! How many times did it take? I'm paranoid about burning the motor out. Quote Link to comment Share on other sites More sharing options...
JetSet Posted May 4, 2014 Share Posted May 4, 2014 Mine did this after not being opened for a while, I just worked it back and to on the switch until it eventually went down all the way of its own accord, been OK ever since! How many times did it take? I'm paranoid about burning the motor out. It took 6 or 7 attempts to get ours down a couple of weeks ago. As soon as it sticks then release the open button and close it again. Next time you try, while its in the position in the above photo apply some grease to all of the joints you can find, you can also give the hood a bit of a push but don't force it down. As already stated its a common problem, we've experienced this every year in the spring first time we've taken it down for 4 years. Pete 1 Quote Link to comment Share on other sites More sharing options...
Floydbax Posted May 5, 2014 Share Posted May 5, 2014 ^ Yea, took mine a few times too, you don't need to close it all the way just back and to a little on the rocker switch to the point where it is sticking, I personally wouldn't be that worried about burning the motors out, if they go - then they would have been on the way out anyway, they are designed to do millions of operations without burning out! Funny, Pete, I'm just over the border in Cheshire and the OP is near Manchester, maybe it's something in the air? Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted May 5, 2014 Share Posted May 5, 2014 I'm in Clitheroe about 40min drive from you . So if you are about my way one day let us no . Has the hood had any repairs on if at all? Will pick up some silicon Grace from work and keep it handy Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Kev Posted May 5, 2014 Author Share Posted May 5, 2014 (edited) My roof is down Thanks for the advice. Edited May 5, 2014 by Kev 3 Quote Link to comment Share on other sites More sharing options...
Will370z Posted May 5, 2014 Share Posted May 5, 2014 Well done, lovely car, reminds me of my old zed. Loved it 1 Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted May 5, 2014 Share Posted May 5, 2014 How many attempts.. Quote Link to comment Share on other sites More sharing options...
Kev Posted May 5, 2014 Author Share Posted May 5, 2014 It's been a good day. Roof down at first attempt and I found the logbook and fsh in the boot 1 Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted May 5, 2014 Share Posted May 5, 2014 It's been a good day. Roof down at first attempt and I found the logbook and fsh in the boot Did you put some grease on the joints and hinges, Have you just got your Zed ?. Quote Link to comment Share on other sites More sharing options...
Kev Posted May 5, 2014 Author Share Posted May 5, 2014 I didn't grease them. The car had been stood in a multi-storey since last august so the roof fabric was a bit stiff. The owner told me he'd lost the log book and service history so I was pleased to find both in the boot. I've had the car for around a week. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted May 5, 2014 Share Posted May 5, 2014 I didn't grease them. The car had been stood in a multi-storey since last august so the roof fabric was a bit stiff. The owner told me he'd lost the log book and service history so I was pleased to find both in the boot. I've had the car for around a week. That explains the roof Kev, would be any harm giving it a bit of lube. Nice find getting the service book and log book, Enjoy it for the Summer. 1 Quote Link to comment Share on other sites More sharing options...
Kev Posted May 5, 2014 Author Share Posted May 5, 2014 I normally go for German cars but I really like the 350z. If we get along over the summer I might PX it for a 370z. 1 Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted May 5, 2014 Share Posted May 5, 2014 I normally go for German cars but I really like the 350z. If we get along over the summer I might PX it for a 370z. Don't worry Kev you will enjoy it .. Quote Link to comment Share on other sites More sharing options...
Ridz Posted May 5, 2014 Share Posted May 5, 2014 Welcome to Zed World! Enjoy driving your Roadster and don't worry about the roof, they all do that when the roof canvas is cold. Quote Link to comment Share on other sites More sharing options...
