Fluke Posted May 2, 2014 Share Posted May 2, 2014 On my way home, I pressed my cruise control start switch, the light comes on but pressing the speed set switch it does nothing. The the light does not even illuminate? Can anyone offer suggestions to what it might be? Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted May 2, 2014 Share Posted May 2, 2014 Iirc there is a switch on the clutch pedal, worth a check I know this does the synchro on the 370 but I think it's cruise related ? Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted May 2, 2014 Share Posted May 2, 2014 http://www.350z-tech.com/forums/123-maintenance-repairs/60855-cruise-control-won-t-engage.html Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted May 2, 2014 Share Posted May 2, 2014 Probably not the same thing but when my cruise control stop working it was intermittent and was due to my clutch going. I could set a speed but if I tried to up the speed with the switch or use the switch to return to the previous speed after slowing down it would cut out. Quote Link to comment Share on other sites More sharing options...
zippypooz Posted May 2, 2014 Share Posted May 2, 2014 Make sure your foot isn't resting on the clutch. Just in case!! Quote Link to comment Share on other sites More sharing options...
BACON Posted May 2, 2014 Share Posted May 2, 2014 It could be related to the issue I am currently trying to resolve.........strangely my issue is a fault with a flashing ABS light!!! This may seem strange but my fault it appears is due to a more level of communication from the electrics into the drivers airbag through a part called the 'Clock Spring'. The clock spring is the part that all of the airbag, stereo and cruise control wiring is located (basically anything that is controlled from the steering wheel controls or the stalks. My clock spring it seems is not passing a strong enough current (not technically minded so I might not be explaining this too well) and therefore the ABS system sees an intermittent fault and flags it as serious......I suppose the possibility of the airbags possibly going off at the correct time is serious but it will be costing me a hefty sum! Quote Link to comment Share on other sites More sharing options...
Floydbax Posted May 2, 2014 Share Posted May 2, 2014 Clock spring sounds possible. Is the warning light flashing? Fairly easy fix and n9t stupidly expensive. Quote Link to comment Share on other sites More sharing options...
Fluke Posted May 3, 2014 Author Share Posted May 3, 2014 No flashing lights, but last week I swapped my steering wheel over. Strange thing is that cruise control was working after the swap, it's only just stopped working. Quote Link to comment Share on other sites More sharing options...
Lexx Posted May 3, 2014 Share Posted May 3, 2014 Check all your connections behind/in the new steering wheel and clock spring. Could have had a wire come loose. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 3, 2014 Share Posted May 3, 2014 Hi OP, Just had exactly this on the shed, a Volvo S60 T5. Did a fair bit of research & 8 times out of 10 it seems to come to clutch or brake pedal sensors which wear out. Safety feature so if they fail cruise won't work. Occasionally it's down to vacum pump. Under £50 for both genuine Volvo parts & easy to fit. Quote Link to comment Share on other sites More sharing options...
Mason iabtyk Posted January 12, 2024 Share Posted January 12, 2024 I need some help badly, so my cruise control doesn’t work at all no light nothing we have tested power to the buttons they work , the clock spring is bypassed ,we have checked the fuses all work ,and the clutch button and brake button both push all the way in I really need help Quote Link to comment Share on other sites More sharing options...
