Better fix for Bose sub cutting out - replacing relay
Jimbo Mahoney
EDIT - PROBLEM SOLVED USING FARNELL RELAY - SEE FURTHER DOWN THREAD.
Recently purchased a 2004 zed with the usual sub cutting out problem.
I've done the bodge fix of sticking a spacer to the top of the relay and also resoldered the pins just in case there was a dry joint.
I've yet to test thoroughly, but does anyone know of an equivalent relay to replace it with?
The thread here:
http://m.my350z.com/...9697&styleid=70
Gives what seems like a good part code, but when I go buy it, mouser want £12 shipping for a £2.50 part because it's coming from the US!
Had a quick look on maplin, but nothing similar I can see.
Alternative would be to buy 12 of them and sell them on with an extra £1 to cover my costs.
Any takers?
Edited by Jimbo Mahoney
I'd be interested in something like this....
I still have two 12's and an amp sat at home waiting to be put into the Z, but I hardly ever listen to the radio and so don't see the point of adding all that weight...
What would be nice though, is that when i do listen to the radio, it worked.
The closest I could fine for sale in the UK is from Farnell.
http://uk.farnell.co...-20a/dp/2008759
Basically the same, but this relay has a slightly lower coil resistance by around 40 ohms. Maybe worth trying it anyway? I don't suffer from the problem...yet...
Awesome thanks!
Farnell have a minimum order of £20, so I've asked my work if they can add it to an upcoming order. I couldn't find another £19 worth of stuff I needed sadly.
Keep you posted...
If you want to replace the relay you can use panasonic JS1-12v-F relay .It is slightly larger than the relay fitted but if you look carefully at the pcb it is drill and marked for both sizes there is a white box on the pcb .
please note the pcb is coated with a conformal coating that will need to be removed prior to soldering to allow a good connection useing this relay solved the problem .
you will of course need a soldering station or at very least a good soldering iron 35w to 50w should do it
you can source the relays for £2.70 with free post on ebay
  • 3 weeks later...
Just soldered the new relay in and it's all working well - thanks again!
Fantastic. Ive now cursed myself, seems the hot weather has caused mine to break. Past few weeks its turned off 3 times. Need to get one of those relays ordered now! haha.
EDIT: You can also buy these from Ebay currently from this link. 3x the cost of the item on Farnel, but if you don't meet their minimum order price of #20, the eBay link is cheaper anyway.
http://www.ebay.co.uk/itm/like/390813571045?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108&ff19=0
Edited by cs2000
