Window Switch
ajh350z
Just after a bit of advice from those in the know before I go fault finding.
Removed my door panel, removed and re-sprayed the plastic window switch panel. When I re-assembled it the window won't work.
The wiring all looks fine, just wondering if I've taken out a fuse? Anyone know where the fuse is located?
Driver's side window is working fine, passenger window won't work when operated from the driver's side either.
