Seany boy Posted April 24, 2014 Share Posted April 24, 2014 Hey guys , long story short.... Iv got a 55 plate DE zed, after a rebuild I ran I to electrical problems and the car wouldn't spark and the injectors wouldn't open... After a lot of testing / checking / changing parts she runs but only if the Crank Position Sensor is unplugged... With it plugged in the car cranks strong but won't muster fuel or a spark Any ideas where I should be looking next ? Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted April 24, 2014 Share Posted April 24, 2014 This...? http://www.clarkmotorsport.net/parts/Camshaft-Position-Sensor-Left/23731%2DAL61A Or This...? http://www.clarkmotorsport.net/parts/Camshaft-Position-Sensor-Right/23731%2D6J90B Or both? Quote Link to comment Share on other sites More sharing options...
Seany boy Posted April 24, 2014 Author Share Posted April 24, 2014 Already fitted New crank sensor New LH cam sensor New RH cam sensor Ecu Wiring harness Ecu is coded as is the key (light goes off the dash etc) Also had alsorts of code readers on it and they all say it's clear , to check I unplug a sensor and it brings the fault up Quote Link to comment Share on other sites More sharing options...
neo Posted April 24, 2014 Share Posted April 24, 2014 zmanalex might be able to help Quote Link to comment Share on other sites More sharing options...
M13KYF Posted April 25, 2014 Share Posted April 25, 2014 or speak to the guys at Abbey Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted April 26, 2014 Share Posted April 26, 2014 hi, well as you say it will only run with the CPS disconnected this leads me saying the flywheel is bolted on in the wrong postion; The cars ECU works out that the CPS signal isn't in the correct position or the signal isn't the correct waveform it will then read the cam signal and run the car on the cam signal, this will also stop the variable cam control not to work this can be also looked at with a good code reader. any questions ask away. thanks Quote Link to comment Share on other sites More sharing options...
