Squeaking brakes?
nowhereboy
My brakes are squeaking like mad and it's doing my head in!
I've had new pads all round and the brake pipes have all been replaced to get it through the MOT. It was squeaking before this and still has the problem now.
Car passed it's MOT no problem tho, any ideas what could be causing this?
Shims were fitted to the OEM pads so if there is none there now they are a good idea.
You also need to make sure everything is properly clean and moving freely, a lot of garages don't spend enough time doing this and noise starts to occur.
If its an OEM spec pad you are running then you shouldn't get noise
