Pro bolt - Strut Brace
Ceejay29
Hi,
I want to replace the OEM strut brace bolts, the three that bolt down the feet and the single nut either side. I will probably go for Pro-Bolt.
Does anybody know what thread/length I need etc? I have the H-Dev plenum spacer and rings fitted to lift the strut brace.
Thanks
I
Brilliant, thanks Greg :)
........oh I presume there isnt a different between JDM (which I have) and UK?
I used:
Bolts M10x(1,25)x30mm http://www.pro-bolt....ml#.U1fy4JJdV8E
Nuts M10x(1.25) http://www.pro-bolt....ml#.U1fzVpJdV8E
Did you buy washers too? Getting pricey :scare:
It should not matter if its a JDM, it will be the same size etc.
I did buy washers.
You can buy the same size bolts in stainless steel which are half the price of titanium bolts.
I've spent well over £1,000 on spacer bolts since doing the kits so I've had to trawl many suppliers and the main strut bolts are the hardest to source. Luckily the spacer kit doesn't need the sprocket nut to be replaced.
I think Greg is right. A few topics suggest M10's. Oh well we will see.
There M10's i have just checked the receipt.
Not to mention i used one of these to check the sizes :http://www.pro-bolt.com/workshop-other/essential-items/pro-gauge-bolt-measuring-tool-essential-item-for-tool-box.html#.U1lgUZNdV8E
Oh and i have been an engineer for 24years therefore know a little bit about nuts and bolts :lol:
