leebottrill Posted April 23, 2014 Share Posted April 23, 2014 I noticed this morning that my door seems to be letting water in! when i open the door there is a pool of water sitting on the plastic strip where the chrome zed badge is. I will pop a photo up in a bit and show you where i mean! I'm guessing just having the seals redone world solve the problem? Anyone else has this problem? Quote Link to comment Share on other sites More sharing options...
KyleR Posted April 23, 2014 Share Posted April 23, 2014 I only have this problem when I use a pressure washer on the car. Seals are on their way out. Hope they're not too expensive or maybe there is a way to recondition them? Quote Link to comment Share on other sites More sharing options...
Almeida1234 Posted April 23, 2014 Share Posted April 23, 2014 Most definitely rubber seals on top worn out or have cracked in areas due to age and wear Quote Link to comment Share on other sites More sharing options...
leebottrill Posted April 23, 2014 Author Share Posted April 23, 2014 Easy job to fix? Quote Link to comment Share on other sites More sharing options...
Grundy Posted April 23, 2014 Share Posted April 23, 2014 Is yours a roadster or coupe? My seal has a slight split in next to the door pillar, as Kyle says, when I use a pressure washer, tends to seep in. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted April 23, 2014 Author Share Posted April 23, 2014 Roadster! I've not had water in the car yet. I'll pop a pic up in a bit! Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted April 23, 2014 Share Posted April 23, 2014 Good idea is to put a slight smear of vaseline on the seals in Winter to stop them sticking and splitting. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted April 23, 2014 Share Posted April 23, 2014 Good idea is to put a slight smear of vaseline on it to stop them sticking and splitting. Slightly edited, but always great advice Quote Link to comment Share on other sites More sharing options...
leebottrill Posted April 23, 2014 Author Share Posted April 23, 2014 ok. i have got water in the car. just went and had a look and the carpet is damp. i'm popping up to the mechanic next week bleady thing! Quote Link to comment Share on other sites More sharing options...
leebottrill Posted May 6, 2014 Author Share Posted May 6, 2014 (edited) Update, well i've had the mechanic look and the door. and seal anything up that needed (including my loose mirror) and this morning the pool of water has arrived back. Can anyone help? Only thing i can think is new seals?? Anyone else had this problem? Edited May 6, 2014 by leebottrill Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted May 6, 2014 Share Posted May 6, 2014 Is your window going all the way up when you shut the door? Mine has a small gap of about 1mm, which lets a bit damp in, if I put my hands on the glass it pushes up and seals properly. It's after the window drop happens, so it doesn't quite go all the way back up. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted May 6, 2014 Author Share Posted May 6, 2014 yea the windows are fine. they do that little extra when i shut the door! the guy did a smoke test and found where it was coming in but didnt know what to do about it! Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted May 6, 2014 Share Posted May 6, 2014 I'm not sure how much the OEM door seals cost but would it be worth getting one or a pair from a breakers off a low mileage Zed. Treat them with Gummi Pflege, that should keep them in good condition and prevent them from going hard or cracking. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted May 6, 2014 Author Share Posted May 6, 2014 Yea good idea. They look fine though! Very frustrating! My carpet isn't actually wet so I'm not going to panic. Does the zed carpet have a plastic lining? I'm wonxring if the water would be going under the lining and I wouldn't feel the damp! Quote Link to comment Share on other sites More sharing options...
