tim Posted April 21, 2014 Share Posted April 21, 2014 I assume it is just a battery problem! Both key fobs do not want to unlock the car sometimes and I get a lock symbol on the dash that looks sad. Am I correct ad us need batteries replacing?? Regards TIM Quote Link to comment Share on other sites More sharing options...
ChrisS Posted April 21, 2014 Share Posted April 21, 2014 What year ? Has your car had a recall for the steering lock to be changed. If not have a search, there are a couple of threads about this. (the vin no on the thread will help you find out if it should be) Quote Link to comment Share on other sites More sharing options...
tatooandy67 Posted April 21, 2014 Share Posted April 21, 2014 Hi tim, had the same issue not long after picking up my 370.... My first thought was oh s#Â¥* after reading about the steering lock issue, as above check on here for up to which vin numbers are affected..I think the affected cars are up to around mid 2010.. Luckily mine turned out to be batteries needed replacing in the fobs very cheap and easy fix, there is a how to thread on here somewhere I would try changing fob batteries first and take it from there good luck 1 Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 21, 2014 Share Posted April 21, 2014 When my battery was getting low it showed a pic of a key and battery level indicator on the dash Quote Link to comment Share on other sites More sharing options...
Ebized Posted April 21, 2014 Share Posted April 21, 2014 Not sure when your 370 was built but see here in case it is steering lock failure related: http://www.350z-uk.c...-recall-action/ Basically, it was cars with a VIN number UP TO 0300691 and build date UP TO 24th March 2010 that the recall applies to. Otherwise it might be a coincidence that both key fob batteries need replacing, but as said above ^^^ there is is normally a digital warning in the dash to that effect. If the car is still under warranty certainly get it along to a Nissan HPC. Quote Link to comment Share on other sites More sharing options...
flyboy Posted April 21, 2014 Share Posted April 21, 2014 When my battery was getting low it showed a pic of a key and battery level indicator on the dash Mine does this even with fresh batteries in the fobs. Some other problem? Mine has had the steering lock done called in and asked Nissan at a service counter and they looked on their database for me. Quote Link to comment Share on other sites More sharing options...
tim Posted April 22, 2014 Author Share Posted April 22, 2014 Many thanks I will see to it later today & let you know. RegardsTIM Quote Link to comment Share on other sites More sharing options...
Cake Posted April 22, 2014 Share Posted April 22, 2014 (edited) Mine did exactly this and was the car battery but replaced fobs too just in case. Check that too, you should be fine on the steering lock Edited April 22, 2014 by Cake Quote Link to comment Share on other sites More sharing options...
tim Posted April 22, 2014 Author Share Posted April 22, 2014 All sorted !!! Cost £12 Sparshatts at Botley are really good. The Chief Techy Dan is a real petrol head I will be taking the 370 there for its annual service. Dan has assured me he will work on the car. I drove the V8 F type not long ago that is some car!! Many Thanks Regards TIM Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 22, 2014 Share Posted April 22, 2014 All sorted !!! Cost £12 Sparshatts at Botley are really good. The Chief Techy Dan is a real petrol head I will be taking the 370 there for its annual service. Dan has assured me he will work on the car. I drove the V8 F type not long ago that is some car!! Many Thanks Regards TIM What did he do ? Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted April 22, 2014 Share Posted April 22, 2014 Just replaced the battery on mine, both working perfectly fine, no more key battery warning on the dash. Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 22, 2014 Share Posted April 22, 2014 Just replaced the battery on mine, both working perfectly fine, no more key battery warning on the dash. I put a spare in the glovebox (just incase) Quote Link to comment Share on other sites More sharing options...
tatooandy67 Posted April 22, 2014 Share Posted April 22, 2014 Sweet, glad you got it sorted, now you can enjoy your wonderful zed Quote Link to comment Share on other sites More sharing options...
Harryjax Posted April 22, 2014 Share Posted April 22, 2014 (edited) All 370z owners I've got limited stock of batteries for the 370z key fob. If you want some for free. PM me your name and address. First come first served. Added 23/4/14: the batteries I'm giving away are Panasonic CR2032. Edited April 23, 2014 by Harryjax Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 22, 2014 Share Posted April 22, 2014 All 370z owners I've got limited stock of batteries for the 370z key fob. If you want some for free. PM me your name and address. First come first served. very kind of you Quote Link to comment Share on other sites More sharing options...
flyboy Posted April 22, 2014 Share Posted April 22, 2014 Just replaced the battery on mine, both working perfectly fine, no more key battery warning on the dash. Branded batteries or generic? just changed mine again for 210 mAh generic ones and still the same key shows on dash.. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted April 22, 2014 Share Posted April 22, 2014 Duracel. Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted April 23, 2014 Share Posted April 23, 2014 (edited) Just replaced the battery on mine, both working perfectly fine, no more key battery warning on the dash. Branded batteries or generic? just changed mine again for 210 mAh generic ones and still the same key shows on dash.. Mine does this but not often, I would say 1 in 20 times but it's ok after and indicates its 75% full ? But as I say it's fine after so I just assume its not read it quite right It still starts and releases the steering lock etc, doesn't cause any issues Edited April 23, 2014 by GIXXERUK Quote Link to comment Share on other sites More sharing options...
Harryjax Posted May 7, 2014 Share Posted May 7, 2014 All 370z owners I've got limited stock of batteries for the 370z key fob. If you want some for free. PM me your name and address. First come first served. Added 23/4/14: the batteries I'm giving away are Panasonic CR2032. If any 370z owners going to Japfest would like some FREE batteries for the keyfob. Give me a shout at fest first come first served. Limited qty left. 1 Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted May 7, 2014 Share Posted May 7, 2014 All 370z owners I've got limited stock of batteries for the 370z key fob. If you want some for free. PM me your name and address. First come first served. Added 23/4/14: the batteries I'm giving away are Panasonic CR2032. If any 370z owners going to Japfest would like some FREE batteries for the keyfob. Give me a shout at fest first come first served. Limited qty left. a generous offer I took advantage of Thanks ! 1 Quote Link to comment Share on other sites More sharing options...
Will370z Posted May 7, 2014 Share Posted May 7, 2014 All 370z owners I've got limited stock of batteries for the 370z key fob. If you want some for free. PM me your name and address. First come first served. Added 23/4/14: the batteries I'm giving away are Panasonic CR2032. Very generous offer there, nice one Quote Link to comment Share on other sites More sharing options...
