snow foaming a 350z roadster......
DaddyCee
Should be fine, they do say don't jet wash the roof though.
+1 and don't stand too close.
Worth noting as well that as the coupe and roadster are pillar-less (no window pillars) you should always be cautious when pressure jet washing the car in those areas. Far too easy to blow water in past the seals especially with +110bar or whatever most common pressure jet washers are nowadays. :thumbs:
It's best not to snow foam the hood or side windows.
If the hood is cleaned/protected by using any of the better hood cleaning products, then a simple wipe down with dilute car shampoo and a final rinse will keep the hood looking good.
