djtimo Posted June 3, 2014 Author Share Posted June 3, 2014 More work on the beast! Picked up a new torque wrench to help me do the wheel arch stuff. Torquing up the ball joints.. Drivers side fully built! Threads on the break callipers needed retapping out but Its built! Only thing left is to fit the break line clips. Needs a good clean up now! More work tomorrow! 1 Quote Link to comment Share on other sites More sharing options...
fellsteruk Posted June 3, 2014 Share Posted June 3, 2014 looking great !!! took my rear lip off at the weekend ready to fit my nismo spoiler and mine looks just like your the foam tape left behind is a pain, what you use to remove it? Quote Link to comment Share on other sites More sharing options...
djtimo Posted June 4, 2014 Author Share Posted June 4, 2014 looking great !!! took my rear lip off at the weekend ready to fit my nismo spoiler and mine looks just like your the foam tape left behind is a pain, what you use to remove it? I got mine off with a plastic scraper and goo gone gel spray. Then a final wipe down with a clean cloth and meths. Took a few hours mind you Quote Link to comment Share on other sites More sharing options...
djtimo Posted June 6, 2014 Author Share Posted June 6, 2014 Nearly there!!! Picked up some nice fresh 10W-60 Mobil 1 performance oil to treat the zed to after the oil had been sitting for a while. Finished pinning all the ball joint nuts and added the break line clips. Cleaned the break callipers and inside the wheels ready to refit! Quick oil change! (old filter was PITA to remove and had to be stabbed a few times to get it lose) Back on the ground after a epic front suspension overhaul! Now for the alignment and MOT! 2 Quote Link to comment Share on other sites More sharing options...
gsexr Posted June 6, 2014 Share Posted June 6, 2014 Great feeling when its all nice and clean.... Quote Link to comment Share on other sites More sharing options...
djtimo Posted June 6, 2014 Author Share Posted June 6, 2014 Work complete! Back in the garage waiting for his MOT. I could not help myself drive up and down the street just to check for any funny sounds etc, which I'm glad to say there wasn't. The front end felt TIGHT! Ive not driven the zed for a while but the front felt like it had no play in it at all which is nice! Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 7, 2014 Share Posted June 7, 2014 Work complete! Back in the garage waiting for his MOT. I could not help myself drive up and down the street just to check for any funny sounds etc, which I'm glad to say there wasn't. The front end felt TIGHT! Ive not driven the zed for a while but the front felt like it had no play in it at all which is nice! NOT COMPLETE!!! Where's the BGW? 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted June 7, 2014 Author Share Posted June 7, 2014 The BGW needs quite a bit if of work to fit IMO. I want it far back as possible so i need to make some spacers to match the feet to the curve of the boot lid. Gonna MOT it first and sort the wing next week. Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 7, 2014 Share Posted June 7, 2014 The BGW needs quite a bit if of work to fit IMO. I want it far back as possible so i need to make some spacers to match the feet to the curve of the boot lid. Gonna MOT it first and sort the wing next week. +1 I could get some made up, but it's going to take a while as it's low on my list of things to do. 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted June 11, 2014 Author Share Posted June 11, 2014 Need some ideas on which way to go with this? I have made a start with fitting the GT wing but have a few options I need to look at to get it fitted. Option one is have some spacers made to fit the curve of the boot lid, option two is to have full new legs made, option 3 is have the legs bent slightly to allow the mounts to sit right? What do you guys think? Few pics... See what I mean? Any other ideas very welcome Quote Link to comment Share on other sites More sharing options...
Stutopia Posted June 11, 2014 Share Posted June 11, 2014 If it were me, I'd want it to fit and look absolutely spot on, so custom legs would probably be my choice - if the price isn't insane? Quote Link to comment Share on other sites More sharing options...
GMballistic Posted June 11, 2014 Share Posted June 11, 2014 If it were me, I'd want it to fit and look absolutely spot on, so custom legs would probably be my choice - if the price isn't insane? Same here especially as so much time & money has already gone into this car. Failing that or if the cost is insane then I would look at some sort of spacers to suit. Quote Link to comment Share on other sites More sharing options...
parello9 Posted June 11, 2014 Share Posted June 11, 2014 looking awesome Quote Link to comment Share on other sites More sharing options...
djtimo Posted June 16, 2014 Author Share Posted June 16, 2014 (edited) Got the beast MOT'ed today! And under it! Need to get my a** in gear and get the rear end off this winter for poly bushing and powder coating! And Im glad to say he passed with flying colours!!! Now for the fun bit! Made a start mocking up the uprights again. Mocked up on the car (Looks badass! LOL) and used my phone for a digital level, 12 degrees out the legs are.. Bent the legs in a vice using a lot of brute force. Measured and measured again before this bit! Scary! No turning back.. I've used a 32mm hole saw on the inner skin as the boot is made up of 3 skins, thin outer, thicker inner, thin under. The upper two skins are very close and almost touch, the lower inner skin has a large gap and would crush/deform as you bolt the wing down tight IMHO. Ill throw some more pics up when I get them And its on! Its com in off again next week as I have longer rear bolts to go in and some 1.5mm rubber sheet to replace the white foam that comes with the wing. Edited June 16, 2014 by djtimo 3 Quote Link to comment Share on other sites More sharing options...
parello9 Posted June 16, 2014 Share Posted June 16, 2014 that looks sick 1 Quote Link to comment Share on other sites More sharing options...
KrisRatcliffe Posted June 16, 2014 Share Posted June 16, 2014 Not big enough mate Sent from my SM-G900F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted June 16, 2014 Share Posted June 16, 2014 Great job. 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted June 19, 2014 Author Share Posted June 19, 2014 Thanks guys! Still needs tweaking but I'm pleased! Few more wing pic's. Hole sawed sections still need a tidy up Another shot Carbon patches used to cover holes left by OEM spoiler. Quote Link to comment Share on other sites More sharing options...
Grundy Posted June 19, 2014 Share Posted June 19, 2014 Glad you're pleased fella 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted June 25, 2014 Author Share Posted June 25, 2014 (edited) Megan wing test, Just a quick go pro edit to see if the wing was moving about under load No movement tested to just over 100 leptons... Edited June 25, 2014 by djtimo 1 Quote Link to comment Share on other sites More sharing options...
StevoD Posted June 26, 2014 Share Posted June 26, 2014 How much to have you fit mine lol 1 Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 26, 2014 Share Posted June 26, 2014 How have I missed this build thread? Bloody well done, mate, car looks great and it's good to see someone taking pride and doing the work right instead of cheeping out 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted June 26, 2014 Author Share Posted June 26, 2014 How much to have you fit mine lol £5 but thats with my eyes shut! LOL.... Its not to bad just need to measure and measure and measure before drilling! Quote Link to comment Share on other sites More sharing options...
StevoD Posted June 26, 2014 Share Posted June 26, 2014 It's more the bending I'm intrested ib Quote Link to comment Share on other sites More sharing options...
Jp606 Posted June 26, 2014 Share Posted June 26, 2014 I love that wing, looks really cool on your car Quote Link to comment Share on other sites More sharing options...
