My Little weekend project.....
djtimo
FINALY SOME REAR GRIP!
I for got my phone so no pics of the old tires coming off on new going on but when I got home heres some detail of the new meaty rears!
Only have about 5 miles on them so not really heat cycled or scrubbed in but I got grip in 2nd gear in the damp!!Made up!
Final prep work done today :)
More cleaning with a drill wire brush.
Safety first LOL..The seam sealer makes a ton of nasty dust.
Made a start on the job of masking off the dash and rear section of the car.
Cat came to help mask the car off.
Fully masked off now, just need to do the head liner, doors and rest of car tomorrow. Then on to etch primer :)
Another shot of the new meaty tires :)
MR Postman turned up too!
Some beefy new drift works rear camber arms.. On sale and lifetime guarantee!
I have removed another few hundred grams of sealer but this has gone in the hoover :(
Good progress TimðŸ‘ðŸ‘ðŸ‘.
Getting the R888 was one of the best mods I'd done on the car and after doing about 3k miles on them including driving daily since mid December in the awful wet greasy roads I totally sold!!
There is hardly any wear on them still albeit I've one done 25laps at the Ring and half day at Bedford.
The wet grip is decent and predictable but I've been careful to avoid significant standing water.
Pressure wise I'm running 34-35psi for road use and on the track I found 29-30psi to be about right. I always have the rear 1-2psi less than front.
My advice will be to hear cycle them properly before heating the track and inflate them with nitrogen so you have more stable pressure on the track and keep an eye on the temp/pressures until they are stable as the tyre can go off suddenly if too hot. I found this out with Bob on at the Ring on my very first lap on the R888 on the zed.
I have a michelin pressure gauge and just got a mid level pyrometer to keep. Good investment!
Finally there are fantastic deals to be had from oponeo and tyreleader. I got my set 245/40/18 275/40/18 delivered for £700! Considering it used to cost me far more with a set of MPS 255/35/19 295/30/19. More grip for less buck = win win in my book.
Good progress Tim������������������.
Hi mate, yeah the R888's are great. Ive had a set of new ones on the front for ages now and did have a set of old part worns on for awhile but there were well past there best.
Im running the car at a lower 33-34psi on the back too as its lighter now and OEm 35psi in the fronts. Cant wait for a little bit of sun to come and dry the roads off so I can see what there like!!
Edited by djtimo
Edits mods please delete
Edited by djtimo
Finished of the masking this morning ready to start laying some paint :)
First coat of etch primer down :)
I did a few coats of etch primer just to make sure it was a nice even base layer and dried it off with a hair dryer to help speed things up as its cold and damp outside today :(
Struggled with little bits of dust from the clean up coming lose with the hair drier :( These had to be sucked up with a gentle hoover.
First dusting of nissan WV2 gunmetal :)
Few more coats.
Passenger side looks like this too but forgot total any pics lol..
Car is now drying off overnight. Ill shoot the clear coat tomorrow :) Looking miles better now its painted!
This build thread is inspiring, love to see this car at shows this year? Looking forward to seeing what future mods you have planed :) ������������
Thanks mate!
I will try and get to a few show this year but I'm just tied up all the time lol..
Futre mods are on my little "to do" list :)
Edited by djtimo
UPDATE :)
Clear coat has cured now. Masking coming off.
Mr Post man has dropped off some Alu plate for me to make up a heel rest from :)
All masking off and seats refitted. Passenger seat is back in for corner weighting on monday as my new passenger seat will not be here yet.
Next job was to fit my carbon dash blanking plate for where the radio head unit was.
After making a card template the CF was masked off and clamped between two bits of wood to cut on a chop saw.
Nice clean cut :)
Very tight press fit into the back of the dash. Some very small tabs needed to be removed with a chisel.
Added a bead of clear silicone to make sure it does not come lose.
Re-Fitted.
Now to make a heel plate next and fit my new camber arms.
UPDATE
Car goes in monday for set up so I needed to get my camber arms on ASAP.
Local DIY garage again :)
Removing the old arms... WOW the car is dirty underneath i WAS clean a few months back lol..
Eccentric bolt section
You have to drop the roll bar off on both sides to get the bolt out.
New arms in place. The length was matched to the old arms to make sure I'm not a million miles away on camber until monday
  • Like 2
Just picked the car up from the set up.
He did say they have had issues as you always do but safe to say the car is almost underivable lol... on the way home 40mph felt dangerous as the back end was moving about over bumps and shaking the car about while cruising. Im hoping its this huge amount of rear toe in causing these issues.
I'll tell you why in a second.
I dropped the car off this morning to have it set up. It need alignment and corner weight/cross weighting. I get a phone call at 2pm saying they have run out of adjustment on the toe bolts on the rear and its at 10mm in EACH side!! I've quickly ordered some drift works toe arms tonight and will fit these ASAP to sort this issue.
The have completed the the rest of the set up and it just needed to go back in for the toe adjustments when i have fitted the arms.
Ready to go on the scales.
On the scales.
The car was set up with 100KG ballast in the driver seat too.
Old skool racing string set up!
Some of the notes of car weight and set up.. Car weight with just over 1/4 tank of fuel is 1469.5kg 20L of fuel weights 15.1KG so a basic dry weight eg. no fuel is 1454.4KG
The end cross weights were this with ballast in the car.
The car will be going back in with in the next few weeks to have the rear toe sorted so ill let you know how it feels after this!
Edited by djtimo
Strange how people still use string. I came from the Racing World were we used String to set up cars originally and they are good at race tracks but I so prefer a modern alignment rig to base workshop set ups so more accurate I feel.
TBH I would of used an Eibach rear camber/track kit comes with eccentrics to allow the track to be adjusted correctly.
CW's look good diagonally typical RHD car with front right being heavy.
They didn't have a hunter later set up at the shop mate. very basic TBF but were 5 mins from my house and seem to know what there doing lol..
Fitted some grip tape to the drivers footwell.
This will help out when its wet out :)
Also fitted some battery terminal covers as it sits quite close to the rear bulk head.
Still waiting for my toe bolts to come then its back for the last part of set up.
