j20rdan Posted November 10, 2015 Share Posted November 10, 2015 Just read through this entire thread (day off) and the work that has gone into this is unreal, seriously impressive! Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 10, 2015 Author Share Posted November 10, 2015 How have I only just found this thread? Wow!! Awesome interior work in the boot! Do you know all together how much weight you saved? Also what power is this beast running? Thanks man, Not sure on total weight I can't remember! Im hoping to get the car weighed soon so Ill post up that when I can! Power its 469whp similar torque figues. Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 10, 2015 Author Share Posted November 10, 2015 Any one ever had water in the passenger footwell?? Just started to get a small amount of damp in the footwell carpet and mat?? Quote Link to comment Share on other sites More sharing options...
harryjackson Posted November 10, 2015 Share Posted November 10, 2015 Aweaome thanks dude!! Wow I bet that is a super fun motor credit to you. 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 10, 2015 Author Share Posted November 10, 2015 Aweaome thanks dude!! Wow I bet that is a super fun motor credit to you. Very fun.. Just been out sliding about in it 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 13, 2015 Author Share Posted November 13, 2015 Fitted my headset hooks Nice and out the way now when not using them Quote Link to comment Share on other sites More sharing options...
Wasso Posted November 13, 2015 Share Posted November 13, 2015 Any one ever had water in the passenger footwell?? Just started to get a small amount of damp in the footwell carpet and mat?? Have a chat with I4N (Ian) he had the same problem and solved it. Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 13, 2015 Author Share Posted November 13, 2015 Any one ever had water in the passenger footwell?? Just started to get a small amount of damp in the footwell carpet and mat?? Have a chat with I4N (Ian) he had the same problem and solved it. Thanks mate, Ive seen where its leaking in from now. Need to have a good look under the dash to sort it Quote Link to comment Share on other sites More sharing options...
Wasso Posted November 14, 2015 Share Posted November 14, 2015 No worries fella, good to see ya, also great work with TC Media, looks as though you're doing really well 1 Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 14, 2015 Share Posted November 14, 2015 (edited) Nice work mate Ref the water - If its coming under the dash on the passenger side I would point you at the air in let under front windscreen, if you take the outside plastic covers off between the windscreen and bonnet there is a plastic strip on the back of the passenger side one, I have seen those damaged or snapped off, that allows water to run in through the inlet, it then drips down from the fan in front of the passengers knee. Hope it helps Edited November 14, 2015 by Keyser 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 16, 2015 Author Share Posted November 16, 2015 No worries fella, good to see ya, also great work with TC Media, looks as though you're doing really well Thanks mate TC MEDIA is coming on well! 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 16, 2015 Author Share Posted November 16, 2015 (edited) Few new bits for the zed today! Anti-sub strap for my 4 point harness to go tot 5 point. Light weight alu battery holder. Extra heavy duty battery and ground cable. Brake caliper temp strips. (See if I'm over heating the Motul brake fluid) Carbon sheet for blanking off the bose head unit space And a TRS soft tow strap for the rear to match the front. Edited November 17, 2015 by djtimo Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 17, 2015 Author Share Posted November 17, 2015 Started a little work on the zed this afternoon.. Looking at mounting the battery holder.. Battery removed and trim off... Heavy duty cable run through bulk head grommet.. Into the car. Fed though into the boot area. Alu holder drilled ready for riveting. Car drilled and single rivet in.. Painted the holes just for extra rust protection. In place. Battery in place but not fixed down.. More work on this tomorrow when its light again 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 17, 2015 Author Share Posted November 17, 2015 (edited) Little more done on the lightweight zed quest.. Dash centre removed. Passenger side airbag cover removed. Air bag unit. Air bag and mounts on passenger side plus head unit and brackets removed and dash refitted. Dash where head unit is removed will be blanked off with carbon fibre sheet. The head unit and air bag set up have removed more weight from high up and in the front end of the car. plus my battery relocation has helped this massively. Air bag unit head unit. Bose amp. Sound deadening from rear quarters X 2 Rear bulkhead plastics. weight removed = 9.470KG Edited November 17, 2015 by djtimo Quote Link to comment Share on other sites More sharing options...
Grundy Posted November 17, 2015 Share Posted November 17, 2015 great Idea to log all the weight changes. 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 17, 2015 Author Share Posted November 17, 2015 (edited) great Idea to log all the weight changes. Ill weigh some of the other bits that have come out too mate, only some light parts but still counts. Will remove door speakers tomorrow to save another kg or so Next big saving will be the passenger seat i think. Weight balance will be better now as I have lost 16.3kg of battery plus 6kg's of head unit etc, so 22kg ish from the front end today and gained the extra 16kgs way out over the back axle. Edited November 17, 2015 by djtimo Quote Link to comment Share on other sites More sharing options...
Grundy Posted November 17, 2015 Share Posted November 17, 2015 Yeah, will be interesting to see your total weight saving. 1 Quote Link to comment Share on other sites More sharing options...
harryjackson Posted November 17, 2015 Share Posted November 17, 2015 This is super interesting. Where did you buy that battery housing from? Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 17, 2015 Author Share Posted November 17, 2015 This is super interesting. Where did you buy that battery housing from? From demon tweaks mate 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 17, 2015 Author Share Posted November 17, 2015 Yeah, will be interesting to see your total weight saving. I want to get the car weighed accurately as its had loads of bits changed and removed but has extra weight from TT kit and cage?? 2 Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted November 17, 2015 Share Posted November 17, 2015 Bout time the Bose stuff came out 1 Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 17, 2015 Share Posted November 17, 2015 Coming along nicely sir 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 18, 2015 Author Share Posted November 18, 2015 Bout time the Bose stuff came out It was only the head unit/amp and door speakers left anyway! Not i have the intercom that you can plug an iPod into then its not really needed now! Quote Link to comment Share on other sites More sharing options...
djtimo Posted November 18, 2015 Author Share Posted November 18, 2015 Connected up now! (No where sold ring crimp connectors for this size cable! Ended up being ripped off for gold plated subwoofer ones from ripspeed ) Covers back on. All sorted in the boot now too! 2 Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted November 18, 2015 Share Posted November 18, 2015 Nice work Tim. Been there and done with a full strip earlier this year. It makes a big difference as even the plastics weight cumulatively but the car is so raw that so you need to be committed. I've got my zed done to 1380kg now with quarter tank fuel and all the other fluids. I believe the UK spec GT weighs 1600kg with fluids. It's a shame I didn't weight individual parts for reference but this has been done before on my 350z US. The only areas left for me is the window motors, AC compressor and lines and lean replacement for all the glass except windscreen. There probably just under 100kg there but I'll loose about 25kg to my full roll cage and when I get the sc back on. Fwiw I would have done an initial corner weight and put the battery in the best spot to roughly even the weights to make full corner weghting easier. 1 Quote Link to comment Share on other sites More sharing options...
