Stu_2424 Posted April 18, 2014 Share Posted April 18, 2014 After some advice from the experts on here. Ive got some DoDo Juice Red Mist Tropical on its way and wondered how its used best as an aid when drying? Is it as simple as spray it onto the already wet panel and dry with towel? Thanks Quote Link to comment Share on other sites More sharing options...
Jp606 Posted April 18, 2014 Share Posted April 18, 2014 I use Chemical Guys Speed Wipe as a drying aid, which adds gloss, protection and an anti static finish and is completely smear free which means I don't need to buff afterwards. Just spray on the wet panel before you dry it, Red Mist may need buffing after, I've never used it. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted April 18, 2014 Share Posted April 18, 2014 You need ilogikal1, I'd bet he'd know the answer. Sorry not much help I know. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted April 18, 2014 Share Posted April 18, 2014 You need ilogikal1, I'd bet he'd know the answer. Sorry not much help I know. You called? Red Mist doesn't work as a drying aid, it's more a fast curing spray sealant and doesn't mix with water. But when using a water based QD then yes it would just be a case of misting over the wet panel and then towel dry. 2 Quote Link to comment Share on other sites More sharing options...
ChrisS Posted April 18, 2014 Share Posted April 18, 2014 Check out Valet Pro Citrus Bling as a drying aid and it's use for all sorts of other things. Quote Link to comment Share on other sites More sharing options...
Stu_2424 Posted April 18, 2014 Author Share Posted April 18, 2014 You need ilogikal1, I'd bet he'd know the answer. Sorry not much help I know. You called? Red Mist doesn't work as a drying aid, it's more a fast curing spray sealant and doesn't mix with water. But when using a water based QD then yes it would just be a case of misting over the wet panel and then towel dry. Thanks for the response So the car should be dried and then sprayed with red mist tropical as then buffed off with a microfibre cloth? Thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted April 19, 2014 Share Posted April 19, 2014 Thanks for the response So the car should be dried and then sprayed with red mist tropical as then buffed off with a microfibre cloth? Thanks Sent from my iPhone using Tapatalk Yep. On a dry panel, spray on (sparingly) and then buff off. Alternatively you can spray onto a cloth, wipe onto the dry panel and then buff with a dry cloth if you prefer. Quote Link to comment Share on other sites More sharing options...
Stu_2424 Posted April 25, 2014 Author Share Posted April 25, 2014 Thanks for the response So the car should be dried and then sprayed with red mist tropical as then buffed off with a microfibre cloth? Thanks Sent from my iPhone using Tapatalk Yep. On a dry panel, spray on (sparingly) and then buff off. Alternatively you can spray onto a cloth, wipe onto the dry panel and then buff with a dry cloth if you prefer. Sorry just saw your reply, thanks for the direction. Can you recommend a water based QD to use during drying? Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted April 26, 2014 Share Posted April 26, 2014 Sorry just saw your reply, thanks for the direction. Can you recommend a water based QD to use during drying? Sent from my iPad using Tapatalk The two mentioned above are both good choices - Chemical Guys Speed Wipe & Valet Pro Citrus Bling - Megs Last Touch & Finish Kare 425 are the other twon which spring to mind. I'm sure there's plenty more, but they're the ones I've tried and found to work well as both drying aids and QD's. If you're just looking for an outright drying aid though - Dodo Juice Time to Dry or even Demon Shine Spray on Shine works well and is relatively cheap. Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 26, 2014 Share Posted April 26, 2014 I use Last Touch for QD and drying aid, and it works perfectly. Quote Link to comment Share on other sites More sharing options...
Arran Posted April 26, 2014 Share Posted April 26, 2014 Yep I use last touch as a drying aid, once ive rinsed the car I spray last touch liberally around the whole car then dry off with a wooly mammoth. No water spots nothing. Perfect Quote Link to comment Share on other sites More sharing options...
d95gas Posted April 26, 2014 Share Posted April 26, 2014 Yep Meguiars Last Touch is spot on for a "Drying Aid", I have a bottle mixed up at a rate of about 20% QD 80% Water. Wash and rinse the car(s) quick spritz with the QD Drying aid, then dry off. Always given a lovely shine and is just the job if you only want to do a quick wash without having to Wax, etc. And its relatively cheap if you buy it by the 5L Quote Link to comment Share on other sites More sharing options...
Stu_2424 Posted May 11, 2014 Author Share Posted May 11, 2014 Just a couple of quick questions regarding Quick Detailers... When you are planning to wax after a wash would you use the QD as a drying aid or would this lead to the wax not applying properly ? Also found out at Japfest yesterday I used a lot of Meguiars Quick Detailer to clean off the road muck. Would I have been better diluting this before I got there to use less product?? Quote Link to comment Share on other sites More sharing options...
d95gas Posted May 11, 2014 Share Posted May 11, 2014 I've never had any issues with Waxing after using QD as a drying aid and been using this method for years with a variety of waxes. If I go to the shows and need to clean off the car, again I use the QD with about the same mix ratio 80% water to 20% QD......never fails. Quote Link to comment Share on other sites More sharing options...
Jp606 Posted May 11, 2014 Share Posted May 11, 2014 I don't bother using QD whilst drying if I'm about to wax, don't see the point. I use it more to top up gloss between waxing and add protection. Quote Link to comment Share on other sites More sharing options...
