plebpl Posted April 18, 2014 Share Posted April 18, 2014 Hey guys, well a few days ago I was out for a drive and due to a cyclist and a idiotic driver I was given the option of a head on crash or a curbed wheel. Well I ended up hitting the curb quite hard and now my steering wheel is of center. I have had the front wheel tracking checked and have been told its spot on, Is there anything I may have bent that's now causing the issue? Track rod ends are my first thought? For those who care luckily the curbing to my wheel isn't too bad, about a 10cm gauge out of the alloy in one spot only. should cost 20-30 quid to get it fixed but I think I will get my wheels powder coated gunmetal grey at the same time. I appreciate any help! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 18, 2014 Share Posted April 18, 2014 You may well have bent the rack rod which screws into the rod end. However the realignment of the steering wheel is part of the geometry adjustment. Alex. Quote Link to comment Share on other sites More sharing options...
plebpl Posted April 18, 2014 Author Share Posted April 18, 2014 Sorry you lost me with the last bit! can you expand? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 18, 2014 Share Posted April 18, 2014 When the steering geometry is adjusted the steering wheel should be clamped in the straight ahead position prior to adjustment. Alex. Quote Link to comment Share on other sites More sharing options...
plebpl Posted April 18, 2014 Author Share Posted April 18, 2014 So I could just get the steering wheel re adjusted and should be all good again? Sorry for the questions that may seem a bit noobish, Im fine with engines, but suspension I havn't got a clue! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 18, 2014 Share Posted April 18, 2014 Yes, a proper 4 wheel computerised geometry check and adjust will fix your issues providing the rack rod is not bent, however no drama there as I have plenty in stock if required. Alex. Quote Link to comment Share on other sites More sharing options...
plebpl Posted April 18, 2014 Author Share Posted April 18, 2014 How much are you charging for one just so I know in case I need to get it! I really appreciate your help! Quote Link to comment Share on other sites More sharing options...
plebpl Posted April 24, 2014 Author Share Posted April 24, 2014 Had my geometry done today and it has helped massively! It almost feels better than it did before the knock and im pretty sure I havant bent anything now! Thank you very much ZMANALEX been a great help. For you suspention wizards I had the read out below, I know the very basics but im not sure how far out it actually was? is it too bad or not? any info regarding how far out it was will be great. Ryan Quote Link to comment Share on other sites More sharing options...
