wizurd Posted April 17, 2014 Share Posted April 17, 2014 I've just double checked and it says in the motordyne instructions to start at 40 inch pounds. thats tiny though - i can't even find a torque wrench that starts that low. can anyone confirm i'm not just getting the wrong end of the stick? Quote Link to comment Share on other sites More sharing options...
mattross1313 Posted April 17, 2014 Share Posted April 17, 2014 When we were putting my engine back together some of those torque settings started off silly low, almost impossibly low. So I think Chris just nipped them tight, and then moved up through the range according to the book Quote Link to comment Share on other sites More sharing options...
Rosssco Posted April 17, 2014 Share Posted April 17, 2014 (edited) That equivalent to 4.5nm or 3.3 lb/ft, so just tighten them up till they are tight basically (if that makes sense) with a small ratchet. Edited April 17, 2014 by Rosssco Quote Link to comment Share on other sites More sharing options...
Wasso Posted April 17, 2014 Share Posted April 17, 2014 All I do is use a handheld screwdriver with the relevant socket piece. Lightly tighten all by hand so that when you torque you're basically at stage one of the tightening routine. 2 Quote Link to comment Share on other sites More sharing options...
wizurd Posted April 17, 2014 Author Share Posted April 17, 2014 coolio - thanks all - hoped that would be the answer :-) Quote Link to comment Share on other sites More sharing options...
