Trig Posted April 16, 2014 Share Posted April 16, 2014 Anybody changed there's? What did you go for? Any big gains? Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 16, 2014 Share Posted April 16, 2014 I did Stillen Ceramic Coated Headers in mine Not sure about NA gains I made lots but I added a Supercharger, NOS and watermeth injection They say the gains are not huge on an NA 350 though - but if the engine is out they are easy enough to change, doing it in the car is a PITA. 1 Quote Link to comment Share on other sites More sharing options...
R35LEE Posted April 16, 2014 Share Posted April 16, 2014 Doing them with the engine in situ is sooooo much fun Quote Link to comment Share on other sites More sharing options...
Trig Posted April 16, 2014 Author Share Posted April 16, 2014 Quick look on eBay last night top gear manifolds look ok £250 or some nice Megan ones £500. Also looked at throttle body's some nice OBX from US quite cheap. But have to pay import duty. Quote Link to comment Share on other sites More sharing options...
Arran Posted April 16, 2014 Share Posted April 16, 2014 I have dc sports ceramic ones on mine, haven't had the map tweaked yet but does feel much livelier up top Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted April 16, 2014 Share Posted April 16, 2014 You're looking at around 12 hours of labour in fitting manifolds, and that's if you know you're way round the zed well. Average labour is about £50 an hour, your looking at about a £600 labour charge on top of the manifolds. Of you're spending that much I wouldn't put cheap crape in, just in case the welds pop and you need to take them back out. So you could be looking at a £900 bill to gain about 10 BHP max on a n/a engine. BHP per £ its not worth the investment of time and money unless you already have the engine out. Quote Link to comment Share on other sites More sharing options...
Ian Posted April 16, 2014 Share Posted April 16, 2014 Its worth doing imo. People say its not worth doing - on that basis neither is an exhaust or hfc combo seeing as they cost the same for similar gains Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted April 16, 2014 Share Posted April 16, 2014 Its worth doing imo. People say its not worth doing - on that basis neither is an exhaust or hfc combo seeing as they cost the same for similar gains most NA mods aren't worth doing; the best thing to do is save all the money you would have spent on NA mods and just go FI from the offset. the 350Z is the most disappointing car to mod on an NA basis. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted April 16, 2014 Share Posted April 16, 2014 Don't buy any crappy ones though - look at the materials they are made from, you don't want the sucker cracking ! Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted April 16, 2014 Share Posted April 16, 2014 the 350Z is the most disappointing car to mod on an NA basis. Surely that's only true if you're after a giant BHP figure? Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted April 16, 2014 Share Posted April 16, 2014 Yeah, I personally think as long as you understand it's not going to be like a GT3RS engine (unless you have the ££££) - there's nothing wrong with doing bits and pieces. Of course, FI would make more sense but hey, some reasonable gains to be had ! (IMHO) Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted April 16, 2014 Share Posted April 16, 2014 It's worth doing and not going to make just 10hp. There is more to it than that. It's it labour intensive but its not 12hrs. I did mine on a ramp with my mechanic friend in under 5 hours. You could do the same on high axles stands with friends if you are mechanically inclined and have tools. There are a few tricks to help it go easier. Remove the Ac compressor, disconnect the steering rack and coolant pipes on driver side. Buy good quality though I would not buy ceramic coated ones because they are usually made of mild steel which is thermally poor material for exhaust and over time can fail. The ceramic coating is also a gimmick and not the real deal like offered by Zircotec. Get stainless steel and heat wrap with good quality thermal wrap. SS has best thermal conductivity and heat resistant. Protect your fuel lines with reflective wrap as you will loose your heat shield. If you really want to keep cost down use the HR/370ztubular equal lenght manifold which will be a perfect fit and have heat shields but also be cheap from breakers. The only kicker is you need to swap you down pipes(decat/cats/HFC) to HR/370 ones as the DE type will not fit. Goodluck 2 Quote Link to comment Share on other sites More sharing options...
Arran Posted April 16, 2014 Share Posted April 16, 2014 Took us 2 hours to install the dc's on a ramp gearbox was off aswell. Not that bad tbh 1 Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted April 16, 2014 Share Posted April 16, 2014 +1 Should have added that on my post. We also had the GB off but that was to change the clutch all within that stated time andit sure makes life easy. 1 Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted April 16, 2014 Share Posted April 16, 2014 And how long did it take to get the gear box off and re fit the gear box? Quote Link to comment Share on other sites More sharing options...
Arran Posted April 16, 2014 Share Posted April 16, 2014 Total time for me, clutch flywheel and manifolds 4 hours all in not going fast either Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted April 16, 2014 Share Posted April 16, 2014 Great to know, as I'll do the clutch and flywheel at the same time as the manifolds Quote Link to comment Share on other sites More sharing options...
Trig Posted April 16, 2014 Author Share Posted April 16, 2014 Only asked as I maybe buying a engine that's bare so rather than buy standard be worth upgrading it all. It's gona be fitted into a mk1 escort. Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted April 16, 2014 Share Posted April 16, 2014 Only asked as I maybe buying a engine that's bare so rather than buy standard be worth upgrading it all. It's gona be fitted into a mk1 escort. In short. Yes, do it Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted April 16, 2014 Share Posted April 16, 2014 Only asked as I maybe buying a engine that's bare so rather than buy standard be worth upgrading it all. It's gona be fitted into a mk1 escort. In short. Yes, do it of its out of the car then its a 10 min job and worth the effort. Quote Link to comment Share on other sites More sharing options...
