Drivers window goes too high
SHEZZA
Hi folks my drivers window goes to high catching at the top and has now split the rubber seal at the top of the door mirror. It still goes up and down fine and auto drops etc when opening the door. Will carrying out the reset procedure sort this or is there something else a miss. Need to replace the seal but don't won't it splitting again. Any help would be great thanks
Mark
Full reset shoul sort it and then it should not split the rubber.
Make sure it is actually dropping when you open the door though.
Edited by Keyser
