bizz Posted April 14, 2014 Share Posted April 14, 2014 Hi All, I'm after a quick bit of info.... Does anyone know the operating voltage of the fuel level sensor in the 350? Is it 5v or 12v?? Thanks for your help Bizz Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 14, 2014 Share Posted April 14, 2014 Fuel level sensor is resistance based not voltage. Quote Link to comment Share on other sites More sharing options...
richmillions Posted April 14, 2014 Share Posted April 14, 2014 It will have a voltage supply, for example on the Ford fiesta it has a 5v reference supply line fed from the cluster. No idea what it is on the zed unfortunately. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 14, 2014 Share Posted April 14, 2014 The sender doesn't need a voltage its just a variable resistor, check the manual, the display however I would suspect does have a voltage supply. Quote Link to comment Share on other sites More sharing options...
