New knock from front under braking
Keviswatt
Hey folks
Replaced the banana bars last year nut now have a new knock under braking at low speeds.You can see the hub/wheel move slightly when watching
Whats the next culprit likely to be?
Lower control arm bushes? or Drop links?
Cheers
Kev
I would check the drop links first they are pretty common to wear
I second this.. The LCA's aren't likely to allow that kind of play.. but while you are in there test for movement on them (and for that matter all the suspension components) -- You may find something has some play that can be remedied very easily. I'd almost bet on it.
