Randy_Baton Posted April 6, 2014 Posted April 6, 2014 (edited) My boot shouldn't fit like this should it? are there any bolts I can loosen/tighten to create less of a gap? If I look down past my rear quarter window I can see into the area where the boot poppers are but the interior still looks like its sealed. Edited April 6, 2014 by Randy_Baton Quote
ioneabee Posted April 6, 2014 Posted April 6, 2014 have you changed the gas struts - this can cause this if you've put them on upside down Quote
KyleR Posted April 6, 2014 Posted April 6, 2014 The bottom mounts if the boot strut should point down, not bend down and point up. Check them Quote
KyleR Posted April 6, 2014 Posted April 6, 2014 Also the struts themselves should be mounted with the damper to the car (not boot) so that it looks upside down when open. Quote
Randy_Baton Posted April 6, 2014 Author Posted April 6, 2014 (edited) I had just changed the boot struts to (SGS uprated), but I've tried both ways. Rod at the bottom cylinder at the top and vice versa. I did install them the wrong way round first time (rod connected to car, cylinder to boot) as it was easier to get them on, noticed the gap and then tried them the other way round this morning. Edited April 6, 2014 by Randy_Baton Quote
KyleR Posted April 6, 2014 Posted April 6, 2014 What about the mounting brackets? They should point down. Quote
Randy_Baton Posted April 6, 2014 Author Posted April 6, 2014 (edited) That was the issue.So like thisnot like thisThis was mid fix, I had them both wrong. Cheers Edited April 6, 2014 by Randy_Baton Quote
