Low volume Pioneer headunit
iwanprice12
I've recently fitted a new HU to the car, but have noticed the volume sounds 'low' even when it is at the max limit? Is there a reason for this & ways that can allow me to gain more volume from the HU?
Thanks
Do the Buster mod if you're having volume problems..
http://www.350z-uk.c...age__hl__buster
Heard this is the mod to do and will sort it. I was lucky and didn't need to bother doing it with my new Pioneer HU.
Also, I thought I read somewhere before that you should turn off the "speed controlled volume function" on the Bose before removal? I done this before swapping to my new unit, maybe that makes a difference?
Edited by pjf1985
Plus 1for the buster mod it works really well can't turn my HU past 11 ish
All you do is cut the RCA cables from your adapter and strip the ends off to make a + & - out off them and then connect them to the head unit speaker wires :-)
Edited by Briggsybriggs1
