delz0r Posted April 3, 2014 Share Posted April 3, 2014 I'm having my Invidia Gemini installed tomorrow. I can't see any installation instructions in the box, does it come with any? If so, does anyone have a link to them? Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted April 3, 2014 Share Posted April 3, 2014 You don't tend to get installation instructions but... The parts may be labelled drivers and passenger side Go opposite to that as its for the US left hookers. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted April 3, 2014 Share Posted April 3, 2014 Also make sure you put the rear pipe on the drivers side OVER the top of the rear anti roll (near the diff) and not underneath. It will fit either way but you will lose a lot of ground clearance if you go underneath it. Quote Link to comment Share on other sites More sharing options...
delz0r Posted April 3, 2014 Author Share Posted April 3, 2014 Thanks guys. Was just checking. Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted April 3, 2014 Share Posted April 3, 2014 Parts are labelled. Quote Link to comment Share on other sites More sharing options...
Richf Posted April 4, 2014 Share Posted April 4, 2014 I found it very easy , I put the back box on first since it's supported on the rubbers it helps stabilise the other pipes as you fit them I also unbolted the brackets with the rubbers on rather than struggle trying to get the rubbers off in situ As usual just bolt everything together loosely first before starting to tighten Quote Link to comment Share on other sites More sharing options...
