Pioneer avh 2600bt install
Level 7 Boss
You've seen these threads a million times, but I'm just looking for confirmation on what I require to install my Pioneer double din. I'm assuming it is the swc fitting kit in the link?
http://incartec.co.uk/nissan/1929/1034/2056/78/Browser.aspx
Also the unit has a USB connection to the rear, how would I ensure I can connect my phone or USB flash drive when I install, and use mirrorlink?
Lastly is it easy to install a replacement for the Bose amp?
Apologies for the noob questions.
My pioneer rear USB has a little cable which has been routed into the cubby. It originally had a female USB termination (so effectively just moved the USB port from the rear into the cubby) now it has an apple connector.
