Headlight washer jets
fellsteruk
So I got my bumper off and to the body shop today finally managed to get the washer jets off but the external painted bit was a right pain to separate.
I cannot see how I am going to be able to put them back on when I get the bumper back, is there a tip/trick?
If you mean the outside painted part, I've done this once before, I think you just manually pull out the "tube" and then it becomes quite obvious how the outside painted part fixes to the "tube" but I can't remember the detail. If I can work it out though................. :)
Just done mine after fitting oil cooler, pull washer unit out and then attach painted front with 2x short screws best to use a stubby driver.
That is the hard way mate:
The easy way is to simply attach the painted cover to the jet with the 2 screws, and then pull out the "tube" and clip in the jet and cover as one unit.
Edited by ZMANALEX
So you don't need to undo the screws?
Correct. :)
