Kuro Posted July 19, 2007 Share Posted July 19, 2007 Folks, Would anyone know the size of the disc size and piston size for a Brembo setup UK Zed? A Porsche owning friend is looking at maybe using this setup if it could work Thanks! Quote Link to comment Share on other sites More sharing options...
bigphil Posted July 19, 2007 Share Posted July 19, 2007 Folks, Would anyone know the size of the disc size and piston size for a Brembo setup UK Zed? A Porsche owning friend is looking at maybe using this setup if it could work Thanks! front disc 324mm dia and 30mm thick rear disc 322mm dia and 22mm thick Not sure of the relevance of piston size but fronts are 4 pot rears 2 pot. Quote Link to comment Share on other sites More sharing options...
stuey Posted July 19, 2007 Share Posted July 19, 2007 Folks, Would anyone know the size of the disc size and piston size for a Brembo setup UK Zed? A Porsche owning friend is looking at maybe using this setup if it could work Thanks! front disc 324mm dia and 30mm thick rear disc 322mm dia and 22mm thick Not sure of the relevance of piston size but fronts are 4 pot rears 2 pot. can you be a bit more precise phil........... Quote Link to comment Share on other sites More sharing options...
