Wayne350 Posted March 27, 2014 Share Posted March 27, 2014 I am in need of some help, I have a pioneer 3600DAB and all installed with the conversion leads and patch lead for stereo controls. This is my adapter and cable I bought: http://www.ebay.co.uk/itm/400681600960?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 My issue is that my front speakers are not working but they were with the standard BOSE HU, I have connected up the "remote " cable and my sub and rear speakers work fine. someone help me please! Quote Link to comment Share on other sites More sharing options...
Meeerrrk Posted March 27, 2014 Share Posted March 27, 2014 I think the kit I used was the same. You need to do a little fault finding. Are you sure you used the front and rear pre outs of your headunit, not rear and sub or something? I would try swapping the front and rear connections and see what happens. If only the rear speakers continue to work, your Bose amp/front speakers are not working correctly. If the front speakers start working but rears stop, then either your preouts on your headunit aren't working, or your using the wrong connections, or your headunit is only playing out 2 channels for some reason. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Briggsybriggs1 Posted March 28, 2014 Share Posted March 28, 2014 Plus 1 to that you should only use the front and back pre outs not the sub :-) Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
