Front Compression Arm
scodgie
Hi guys, I have just purchased my first zed, the seller advised me that the front compression arm needed changing, it is quite noisey and clattery, Ive no idea what it is, he assured me it was a cheap part and easy fix.. Im now questioning this? is it a specialist job, can say kwick fit do this sort of thing? just am flat broke after buying the car..any help would be much appreciated
Cheers guys
Ian
Hi Ian
Compression arm failure is common on the 350Z, if its the bush thats gone then these can be replaced if its the ball joint then the complete arm is required.
We can supply both and for the bushes either OEM Nissan ones which are not available from a UK dealer or aftermarket from Whiteline or Supepro.
Its a straight forward job but I wouldn't trust Kwik Fit to change a tyre let alone a suspension arm :) you would be better finding a real mechanic, where about's are you based i'm sure someone can recommend a good garage?
Ewen
Edited by Clark Motorsport
Hi Ian
Ewen
Thanks Ewen
Can you give me a price for the parts please and what is your delivery time and cost.
Thanks
Ian
Hi Ian
Ewen
Any tell tail signs to identify if its the bush or the ball joint Ewen?
Thanks Ian,
Compression arms are £250 each and can be found here:
Left - http://www.clarkmotorsport.co.uk/parts/Compression-Rod--Left/54469-CD00C
Right - http://www.clarkmotorsport.co.uk/parts/Compression-Rod--Right/54468-CD00C
The replacement OEM Nissan bushes are £29.99 and can be found here http://www.clarkmotorsport.co.uk/parts/Compression-Rod-Bush/54570-AC70A
You may also require a new seating cone and nut:
Cone - http://www.clarkmotorsport.co.uk/parts/Compression-Rod-Cone/40173-33P00
Nut - http://www.clarkmotorsport.co.uk/parts/Compression-Rod-Nut/01225-00941
All in stock for next day delivery :)
Hi Ian
Ewen
You would need to get the car in the air Kris, with the bush failing normally the rubber starts to detach from the metal outer. With the ball joint that can be a bit more difficult to check but slight play is enough to create a knock.
We seem to sell more bushes than complete arms though.
Thanks Ian,
Left - http://www.clarkmoto...eft/54469-CD00C
Right - http://www.clarkmoto...ght/54468-CD00C
The replacement OEM Nissan bushes are £29.99 and can be found here http://www.clarkmoto...ush/54570-AC70A
Cone - http://www.clarkmoto...one/40173-33P00
Nut - http://www.clarkmoto...Nut/01225-00941
Thanks Ewen, if Ive added up correctly can you do the complete setup for £300 ish.. is that including delivery.
Cheers
Ian
If its an arm, cone and nut you need then the total is £267.98. If its a replacement bush for your arm with new cone and nut then its £47.97.
Website order over £70 have free UK mainland delivery :)
Thanks Ewan, Ive just spoken to the guy who sold me the car and hes saying he thinks its just the bushes.. Im no mechanic, so I wouldnt know either way, is it worth doing the bushes first, or is it pointless if the arm is toast?
cheers
Ian
Hi Ian
Ewen
Thanks mate, I will try and borrow Neilp at the weekend to help. He is much more mechanically minded than me :lol: I hope its a bush but I have a funny feeling it is the arm.
Mine was knocking like mad and making some really horrible squeaking noises and it was the bushes on both sides, the arm was fine.
I'd start with the bush, but remember you need a press to both fit and remove the old bush from the arm.
Ewen, probably a silly question, but why can't the ball joint be replaced? Is it the fact that the metal joint has deformed? :shrug:
Its the design the ball joint is pressed in at manufacture and can not be removed without damaging the arm itself. The bush is a push fit but you will need a proper press 10 ton or bigger to "push" it in/out .
Update guys, and a big thanks to the members who have helped me out on this one.. :), had to change both sides in the end but she is driving lovely now, both ball joints were totally shot, tip for anyone sourcing these compression arms in the future, I got the right hand side arm off ebay from a UK seller for £72 Brand new including delivery, Just typed in "350z wishbone" as apposed to front compression arm.. Once again big thanks guys.
Ian
Ian
Remember Ian they are not the OEM arms as per the left hand arm I supplied you, the quality is not the same hence the price difference :)
Ian
I have no idea of the source of the part Ewen, it seems to be up to scratch and has a 12 month guarantee, but I will be using Nissan parts in future when my budget allows me, Im just a bit penny less after the purchase of the car, I wasnt expecting two components failing immediately or that needed changing, I cant understand how it got through an MOT a week previously to be honest ? They were both totally shot.
Ian
Theyre not tested during an MOT. Most people find that the only way to check is to either take the arm off, or to raise the car up on a ramp and try to wobble the arm with a crowbar as a aid.
I had the same issue with mine when I bought it. Got it for a very good price but it needed two new banana arm bushes (done), new AC radiator (done) new flywheel (not yet done), new boot struts (done), 4x new droplinks (done) and probably a few other bits, I've had it a year and just got the most expensive one to do.
Edited by cs2000
Ian
Thats a lot of work mate.. hopefully fingers crossed Im ok for now, what I have found though is IMO you dont have to go Specialists for the work on these motors, any competent mechanic can do most of the things youd do on your normal daily driver, like suspension, brakes etc.. and shopping around for parts can save you a bucket.
