Engine management light issue
Perry690
Bought my second zed love them to bits. This one been a bit of a pain since I got it have had management light on and off that many times has been to that many different garages but no one seems capable of sorting it. I have had lambda sensor changed as code is always bank 1 bi sensor car runs for approx 100 miles and light on. Has been into nissan they recon it's cat problem have ordered two high flow cats but not sure this is going to solve problem car drives brill anyone help cheers
Clark Motorsport have responded in the other thread you posted in btw; http://www.350z-uk.com/topic/78035-new-cats-engine-management-light-on/#entry1242200
Some very knowledgeable garage traders on here, CS, Horsham Developments, Clark Motorsport and Abbey Motorsport just to name a few. Maybe best to try a PM to the garage closest to you for a better response. ;)
High Flow Cats will still bring up the EML light as mine did but you can turn it off by doing an ECU reset (pedal dance) if you like each time; http://www.350z-uk.com/topic/53148-how-to-ecu-accelerator-pedal-throttle-valve-resets/
...or by having the car correctly mapped for them via an UpRev which is the more advisable option as you'll get the best benefits then & it will run better overall. Not sure whether the 02 spacers will stop it but that's a question you should ask one of the garage traders on here. Good luck. :thumbs:
