RH low beam not working
Keviswatt
I'd agree, assuming the new bulb is known working, and the fuse is ok (1 fuse does both sides so must be fine).
Can try swapping the ballast from the other side to diagnose it, water in the lens sounds like someone didn't refit the grey cap on the back of the lights properly last time a bulb was changed. There are other ways you can get water in there such as a cracked headlight housing, but leaving the cap off slightly is the easiest way.
