Piston rings :( ----> Car Now Sold :(
FUG
Well it appears the piston rings on my car are worn , loss of oil , sometimes power , lots of tinted blue smoke out the back especially on start up ...
My options appear bleak , the local garages won't touch it , nissan won't strip an enginee only replace with a new one ...
What would others do ??
Is it worth the money to sort or just sell it as it is and take a loss ??
I was planning on selling within the year anyway , just has come at the wrong time!!
Edited by FUG
No specialists near(ish) to you? I guess it depends on how much it's worth if it was running properly, how much it's going to cost to repair it and how much you'd get for it in it's current state. Personally I'd try and get some quotes from some of the traders/garages on here and go from there.
Thought about a second hand engine as well? I'm sure I've read on here that you can get a good running one fitted all in for around the £1500 mark? May be worth looking into? Obviously I don't know what you'd be prepared to pay for any of the work either way but I'd definitely get all the numbers together first and see which was the most prudent option. How comes you want to sell up anyway (aside from the unexpected engine problems)?
Good luck though with whatever you decide is best :-)
Current car is an 04 de engine gt model with 50,000 miles , mot and serviced last week and taxed this week
Few dings and dents on the doors and rear tyres need changing
Have had the car 3 years and looking to move out next year but will sorely miss the zed :(
Running well I was thinking maybe £6500 bearing in mind tyres and dents ??
Current state with piston rings what would people think it's worth ? We buy any car reckons 3800 but the declared issues are not tha defined online and I've heard when they come to view it they always peg it down lots
Have you done a compression test? and I would advise a leak-down test as well it will help diagnose exactly what the problem is,
I would not think a DE with 50K on the engine would be suffering from ring seal problems unless severely abused, its the rev-up version that's known for ring seal problems and not the DE.
  • Like 3
do what every one on here seems to do go to the zed shed and get buster to fix it :-)
Sent from my iPad using Tapatalk
Just remember the doughnuts, don't go without doughnuts...
Compression test being done this week
A few weeks back I was stuck in heavy traffic for a while and the fans packed up , coolant went everywhere needless to say engine got very hot and I was towed home , thinking this excessive heat may have fried the piston rings ??
I think its more likely you have blown a head gasket fella, also get a proper leak-down test done.
Edited by Tricky-Ricky
keyser - thanks for the PM , replied to it :thumbs:
garage has told me compression test apparently 1.5 hrs and wont necassarily proove anything , are they trying to con me ?!
I would not go any further without a compression and or leak down test. You can get the compresion kit from halfords for 30quid and do it yourself.
As Ricky mentioned it would likely be a gasket failure of some sort rather than rings failing due to overheating but may even be unrelated to both
Check you pcv it working and not stuck.
In any case the zed shed crew will sort you out.
Taking the mic! 1/2 hour tops, compression test is just a basic check to see if one cylinder is down, and so could indicate a badly blown HG, broken piston ring, badly seating valve, or worst case scenario hole in piston.
However I recommended a leak-down test as this will differentiate between a valve seat problem and ring seal/head gasket, before just dismantling things to find the cause.
But based on what you have said about the engine overheating I would be looking to replace the head gasket/s.
Unfortunately the work required was too extensive and costly and with the signs of things continuously going wrong it was time to sell !
I am absolutely gutted, loved the car and wanted one ever since i was 17. After 2 years of ownership it came to an abrupt end , i was not ready to let go of her !! :(
This has now given me a kick up the back side to save hard to move out by next year. This does however mean getting a 'sensible' run around so unfortunatly will not be returning to a zed for the foreseeable future.
this means a number of goodies will be up for sale soon, will keep you all posted !
I think i tried all garages around here! Including my good friends in clacton
there was a lot needed doing including new fans and rear tyres , door damage not to mention the engine issues :rant:
