nath8642 Posted March 24, 2014 Share Posted March 24, 2014 I know this may sound daft but when checking oil in my 350z I find it hard to get a good reading as when looking at the dipstick it doesnt look like one of the best manufactured piece of kit there is it bends in all directions and when I pull it out I cant get a good reading as oil get everywhere on its way out. Anyone else had this problem and how did you overcome it and how do you know your running low on oil? Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 24, 2014 Share Posted March 24, 2014 It's a load of crap, that dipstick. Best thing to do is to drain the oil completely, then refill and measure: That way you'll have a 100% guarantee that what you're seeing on the stick, however odd, is what a full sump looks like. The other trick is to paint the end of the stick white, with Tipp-Ex or similar. Much easier to read then 1 Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted March 24, 2014 Share Posted March 24, 2014 I think this topic is notorious on the forum. A lot of people think it's hard to read, personally I think it's fine. I'd say just make sure you clean it off once pull out and try 2 or 3 times. if the reading is the same 2 or 3 times then that's the level. You just need to get to know it Quote Link to comment Share on other sites More sharing options...
nath8642 Posted March 24, 2014 Author Share Posted March 24, 2014 yeah I guess so I would have looked but im on my phone and its a right pain scrolling down and zooming in on the forums. Are they notoriouse for running out alot and burning it off if not ill just leave it for the service in a couple of months Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 24, 2014 Share Posted March 24, 2014 Non-revup DE and HR cars aren't known for using a lot of oil, but you should still check on a fortnightly basis at the very least. Definitely not leaving it a couple of months! It's a pain, but you'll have to learn to read the stick. Quote Link to comment Share on other sites More sharing options...
nath8642 Posted March 24, 2014 Author Share Posted March 24, 2014 what is the oil everyone uses ill go buy some today then Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted March 24, 2014 Share Posted March 24, 2014 (edited) Strangely enough, I was reading the 150th ed of banzai on the crapper this morning and came across an article about Milners nanotech. According to the article and a few others I have read it's good for enhancing the performance by a few ponies. Yes please! Edited March 24, 2014 by Rock_Steady Quote Link to comment Share on other sites More sharing options...
glrnet Posted March 24, 2014 Share Posted March 24, 2014 Leave it on a flat and level surface overnight and then check, the dip stick takes a bit of getting used to but you'll get a good reading this way especially if you paint the end of the stick as Dan mentioned. Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted March 24, 2014 Share Posted March 24, 2014 The person who designed the dipstick for the 350Z is a dipstick... 1 Quote Link to comment Share on other sites More sharing options...
evest Posted March 24, 2014 Share Posted March 24, 2014 You need 5W-30 mate. The brand is up to you but personally I buy from Opie Oils, and I get Fuchs Titan Race Pro S 5W-30. Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted March 24, 2014 Share Posted March 24, 2014 You need 5W-30 mate. The brand is up to you but personally I buy from Opie Oils, and I get Fuchs Titan Race Pro S 5W-30. Yep this is what I'd recommend. The dipstick is a very bad design, but I really don't understand how so many people have trouble reading it. - As on any car, park on a level surface. - Do it when the engine is cold so the oil has settled and is at its thickest. - Pull the dipstick out in one move, without turning it. - Once out, quickly read the level. - Its a lot easier if once its out you flip it over and read the level on the back of the stick. If your struggling to see the level its probably not right, i.e too high or too low. As Dan said, do not leave it months without checking it. Personally every week, or before any long journey. Not sure I would put tip-ex on it for fear of it coming off in the oil Heat/oil resistant paint ...maybe. Quote Link to comment Share on other sites More sharing options...
