evest Posted March 22, 2014 Share Posted March 22, 2014 Me that is... So I decided to change my LSD oil today, as the car is now over 10 years old and has over 120K on the clock, I thought it wouldn't do any harm. To keep it short, all I'll say is: make sure you can get the filler bolt out BEFORE you take the drain bolt out! Yes - total moronic lack of common sense... and you can imagine my despair when said filler bolt wouldn't budge and my wrench was simply deforming the female hex slot. Well, in a procedure that was messier than a bad day in the Funhouse (remember that?!) I managed to pump 2 litres of oil in through the drain hole whilst simultaneously trying to plug it with my free(ish) hand. With the amount of oil that escaped during this, I have ended up, more or less, with the specified 1.4 litres in there and the car is thankfully running fine. I'll still be getting some penetrating oil or something to try and get the filler bolt off to check the level properly though... I'm sure that there will be at least one other person out there who will try and do the same thing, so, if you're reading this - learn from my mistake and check that filler bolt first!!! 1 Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted March 22, 2014 Share Posted March 22, 2014 easily done I guess 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 22, 2014 Share Posted March 22, 2014 Followed eventually by.... 3 Quote Link to comment Share on other sites More sharing options...
Almeida1234 Posted March 22, 2014 Share Posted March 22, 2014 Easily done dude, at least you know it next time Quote Link to comment Share on other sites More sharing options...
Robothobo Posted March 22, 2014 Share Posted March 22, 2014 Maybe these two will ease your pain 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 22, 2014 Share Posted March 22, 2014 Maybe these two will ease your pain I bet he shagged them both together, ...lucky bast**d. 5 Quote Link to comment Share on other sites More sharing options...
davedutch Posted March 22, 2014 Share Posted March 22, 2014 Simple solution, just turn the car upside down well someone had to say it!!! hope you manage to get filler bolt out soon, would hate to think you might damage diff due to lack of lube Quote Link to comment Share on other sites More sharing options...
evest Posted March 22, 2014 Author Share Posted March 22, 2014 All options we're being considered about 2 hrs ago, includimg turning her upside down! ! But I'll try a wire brush and plentry of Wd40 first!! Quote Link to comment Share on other sites More sharing options...
djb55 Posted March 22, 2014 Share Posted March 22, 2014 I remember my old man back in the 60, s doing an oil change on his 375 Consul over a street grid, 3 gallon cans of oil later and still no reading on the dipstick and then there sat on top off the air filter pan was the sump plug laughing at him. Sent from my GT-I9300 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
KyleR Posted March 22, 2014 Share Posted March 22, 2014 Good tip, never thought about this actually Quote Link to comment Share on other sites More sharing options...
WhackyWill Posted March 22, 2014 Share Posted March 22, 2014 Maybe these two will ease your pain I bet he shagged them both together, ...lucky bast**d. Think they are his Sisters, but incest is Relative I'm told.. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted March 22, 2014 Share Posted March 22, 2014 Maybe these two will ease your pain I bet he shagged them both together, ...lucky bast**d. Think they are his Sisters, but incest is Relative I'm told.. Got all my cousins to help with the gardening recently ... my garden is now relatively weed free Quote Link to comment Share on other sites More sharing options...
glrnet Posted March 22, 2014 Share Posted March 22, 2014 All options we're being considered about 2 hrs ago, includimg turning her upside down! ! But I'll try a wire brush and plentry of Wd40 first!! At least you had the nuts to admit your mistake. We've all done something silly at some point. And don't use WD40, get some of this http://www.tooled-up.com/product/plusgas-dismantling-de-seizing-lubricant-aerosol-200ml/140169/?Referrer=googleproductlisting&gclid=CPHerv2Gp70CFcuWtAod_moAcA Quote Link to comment Share on other sites More sharing options...
evest Posted March 22, 2014 Author Share Posted March 22, 2014 Thanks mate, I'll look into in! Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted March 22, 2014 Share Posted March 22, 2014 Easily done Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted March 22, 2014 Share Posted March 22, 2014 easily done I guess Easily done There's an echo in here Quote Link to comment Share on other sites More sharing options...
djb55 Posted March 22, 2014 Share Posted March 22, 2014 All options we're being considered about 2 hrs ago, includimg turning her upside down! ! But I'll try a wire brush and plentry of Wd40 first!! I would be ordering a new plug mate and as for getting it out, loads of heat and a good pair of stilsons. Sent from my GT-I9300 using Tapatalk Quote Link to comment Share on other sites More sharing options...
stuarty Posted March 22, 2014 Share Posted March 22, 2014 Me that is... So I decided to change my LSD oil today, as the car is now over 10 years old and has over 120K on the clock, I thought it wouldn't do any harm. To keep it short, all I'll say is: make sure you can get the filler bolt out BEFORE you take the drain bolt out! Yes - total moronic lack of common sense... and you can imagine my despair when said filler bolt wouldn't budge and my wrench was simply deforming the female hex slot. Well, in a procedure that was messier than a bad day in the Funhouse (remember that?!) I managed to pump 2 litres of oil in through the drain hole whilst simultaneously trying to plug it with my free(ish) hand. With the amount of oil that escaped during this, I have ended up, more or less, with the specified 1.4 litres in there and the car is thankfully running fine. I'll still be getting some penetrating oil or something to try and get the filler bolt off to check the level properly though... I'm sure that there will be at least one other person out there who will try and do the same thing, so, if you're reading this - learn from my mistake and check that filler bolt first!!! "my wrench was simply deforming the female hex slot". I like the sound of that, lol! 1 Quote Link to comment Share on other sites More sharing options...
evest Posted March 22, 2014 Author Share Posted March 22, 2014 Me that is... So I decided to change my LSD oil today, as the car is now over 10 years old and has over 120K on the clock, I thought it wouldn't do any harm. To keep it short, all I'll say is: make sure you can get the filler bolt out BEFORE you take the drain bolt out! Yes - total moronic lack of common sense... and you can imagine my despair when said filler bolt wouldn't budge and my wrench was simply deforming the female hex slot. Well, in a procedure that was messier than a bad day in the Funhouse (remember that?!) I managed to pump 2 litres of oil in through the drain hole whilst simultaneously trying to plug it with my free(ish) hand. With the amount of oil that escaped during this, I have ended up, more or less, with the specified 1.4 litres in there and the car is thankfully running fine. I'll still be getting some penetrating oil or something to try and get the filler bolt off to check the level properly though... I'm sure that there will be at least one other person out there who will try and do the same thing, so, if you're reading this - learn from my mistake and check that filler bolt first!!! "my wrench was simply deforming the female hex slot". I like the sound of that, lol! :lol: Quote Link to comment Share on other sites More sharing options...
ZEUS Posted March 22, 2014 Share Posted March 22, 2014 Maybe these two will ease your pain I bet he shagged them both together, ...lucky bast**d. I'm saying nothing mate Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 22, 2014 Share Posted March 22, 2014 Maybe these two will ease your pain I bet he shagged them both together, ...lucky bast**d. I'm saying nothing mate You know you would if you could. Although they're probably both in their 40's by now. Quote Link to comment Share on other sites More sharing options...
stuarty Posted March 22, 2014 Share Posted March 22, 2014 (edited) Maybe these two will ease your pain I bet he shagged them both together, ...lucky bast**d. I'm saying nothing mate You know you would if you could. Although they're probably both in their 40's by now. Many a good tune out of an old fiddle! Edited March 22, 2014 by stuarty Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 22, 2014 Share Posted March 22, 2014 ^^ That is very true stuarty. ...And just look at Kylie Minogue. She's 45 and she doesn't look over 25 to me. 1 Quote Link to comment Share on other sites More sharing options...
Tigerzed Posted March 22, 2014 Share Posted March 22, 2014 + jennifer Aniston courtney cox oh and for those who saw a picture in a previous thread this evening Linus's mam ........ all in their 40s and gagging for it 1 Quote Link to comment Share on other sites More sharing options...
