d95gas Posted March 21, 2014 Share Posted March 21, 2014 Just been out for a drive and clutch is starting to slip in 3+ gears. I guess its probably the original clutch as its just clocked 51,048 and came with full service history and there is no mention of the clutch having been replaced. Is there anyone reputable and fairly priced in the "Darlington" / Co Durham area that you guys can recommend? Is it necessary to change the flywheel, or will this be dependent on the condition. Car has always driven well with no nasty noises from the gearbox/clutch area. Hoping someone can recommend someone local.......If I could get it on the ramps at work I'd do it myself.....Can't be that bad a job Thanks Quote Link to comment Share on other sites More sharing options...
Almeida1234 Posted March 21, 2014 Share Posted March 21, 2014 I recommend changing the flywheel at the same time. Clarke motor sports do a good deal on clutches and flywheels so give them a pm. Quote Link to comment Share on other sites More sharing options...
hensh65 Posted March 21, 2014 Share Posted March 21, 2014 On 21/03/2014 at 10:18, Almeida1234 said: I recommend changing the flywheel at the same time. Clarke motor sports do a good deal on clutches and flywheels so give them a pm. +1 Would be a shame to change the clutch then you get issues with the fly then it will be even more labour costs. PM Clarks for their options Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted March 21, 2014 Share Posted March 21, 2014 Thanks guys There is a number of options depending on your needs, normally always advisable to change the flywheel at the same time as the DMF units in the cars don't tend to last and will normally be worn once the clutch has reached the end of its life. Drop me a PM or give us a call if I can help Ewen Quote Link to comment Share on other sites More sharing options...
d95gas Posted March 21, 2014 Author Share Posted March 21, 2014 Thanks for the info guys, really appreciated.....and would seem foolish not to take your advise about the flywheel. Ewen I will PM you. Graeme Quote Link to comment Share on other sites More sharing options...
Flex Posted March 22, 2014 Share Posted March 22, 2014 You've also got r35lee if you fancy a trip down to Middlesbrough Quote Link to comment Share on other sites More sharing options...
d95gas Posted March 22, 2014 Author Share Posted March 22, 2014 Already pm'd and will be speaking to them Monday, thanks anyway Graeme Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted March 22, 2014 Share Posted March 22, 2014 We fitted two clutches last week on Zeds and on both occasions we needed to swap out the flywheel too... Quote Link to comment Share on other sites More sharing options...
Zhorno Posted March 22, 2014 Share Posted March 22, 2014 How much does it cost for average clutch to be fitted Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
