Lower suspension arm help
mark_j
my 350z just failed mot on the bush for this arm, may be called banana arm? nissan want £250 plus vat for the part!! ouchh, can anyone help source a press in replacement bush or alternative part, also timescales to fit, my MOT station seem to think it will take a very long time as subframe has to come out, please help or point me in the direction of a good indie, bristol / somerset area. many thanks
Its straight forward for the home mechanic too, just be careful not to snap a bolt on the bracing, use a good penetrating fluid, something like Metaflux...
If he's only replacing the bushing then it will need to be pressed out by a garage or someone with a big press.
And you should also have an alignment done.
Edited by Jp606
