ross27 Posted March 16, 2014 Share Posted March 16, 2014 Ive owned my 370z for around 4 weeks now, and in that time ive not been too impressed with the clutch. One time i was giving it some beans, i ended up with the clutch pedal loosing pressure and struggling to come back up. (I fear i may have the CSC problems i read about on the US forums) After that happened i check the clutch fluid, and it was on the minimum line, so i planned to do a full flush. The stuff in the reservoir was thick and black, and didnt look like it had been changed in the cars lifetime (2010, 32k). This morning i nipped down to Halfrauds and got a bottle of Mobil Dot4, and with the assistance of my Dad, i bled the system out. Started by sucking out the fluid from the reservoir, then jacking up the car and locating the bleed nipple. This is on the passenger side of the transmission, and has a small rubber cap on it. You need an 8mm spanner to loosen. This video shows the exact proceedure i follwed: I must have done around 14 cycles untill i was happy with the fluid coming out. To compare, i poured some of the new stuff in a bottle! Take a look at yours, and if it is very dark, i suggest you replace it! I also lowered the clutch pedal and the difference is very noticeable! 2 Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted March 16, 2014 Share Posted March 16, 2014 good post ross Quote Link to comment Share on other sites More sharing options...
ross27 Posted March 17, 2014 Author Share Posted March 17, 2014 good post ross Cheers, hopefully its helpfull to someone! I was surprised at the colour, and cloudyness of the stuff coming out the bleed nipple!! Quote Link to comment Share on other sites More sharing options...
