Been in storage since September, is a service necessary?
sloutrou
Hi all,
My car has been in storage for the winter months since September last year and plan on bringing her back out for the start of April.
Question is, I had a P3 service done late August, do I need another before it comes back out, change the oil, spark plugs, etc, or will it be fine?
More than happy to pay for a P1 if you guys think it'd be a good idea.
Jez
personally i wouldn't go the whole hog, plugs etx should be all fine after sitting a little while. Oil is a thought (i like to change mibe every 6 months regardless) but the ones i would think about would be a quick check for mould etc on air and pollen filters then check the water content of the brake fluid (its hygroscopic so absorbs moisture from the atmosphere which can create little bubbles when your brakes get up to heat). Otherwise aside from brakes probably being a bit sticky, you should be good
