Passenger Window Switch Trim: How do I remove??
Darren350
As the title suggests guys, how do I get the passenger window switch trim off?
I thought you removed the silver handle trim, then the handle, then the window switch trim. But I can't yank that first silver bit off for the life of me! Help please!
Sent from my GT-I9300 using Tapatalk
Take a small flat bladed screwdriver and carefully lever from either the top or bottom until you can grab the silver bit and then once the silver bit is off, you can undo two screws that hold the handle on. Then when handle is removed, you can yank the window switch trim.
Removing the pad helps to get a hold of the trim too.
Hope this helps
So I do have the right idea then in removing that silver panel section off the handle first? Guess I'm just not strong enough lol
Yup, you're process is correct, just need to try a bit harder. It's metal so it won't break, but may bend, so just be firm but careful :)
