few questions
Face
Hi guys
Picked my new 350z up yesterday and i have a few questions
First is
If i have the radio off and just listening to the beautiful sound of the engine, i can hear a faint rumble coming from the rear left wheel i think.
best way to describe it - it's like if you was going over a rumble strip on the hard shoulder (but you had ear plugs in)
Second is
Rear parking sensors are really quite
best way to describe it - it's like if you had parking sensors(but you had ear plugs in) :teeth:
Third is
Gear change from 1st to second is clunky, the rest of the gears are smooth but shifting from first to second is clunky
Best way to describe it - It has nothing to do with ear plugs in :lol:
Any advice much appreciated
Cheers
First one sounds like a bad wheel bearing, last one is normal, but a gearbox oil change and adding Molyslip really improves this. If you are handy with a spanner it's extremely easy to do yourself.
+1 :)
I was going to say the same. parking sensors are after market so depends who fit them and what make. might be hard to find out but i'm sure there would be setting or resistor to change this.
might be more hassle than it's worth to be honest.
the park sensor kit was an optional extra and was fitted by the dealer so kits can vary depending on what the dealer fancied, the buzzer is in the boot, find it and check the connections, poor connections often give a low volume (give it a knock)
worst case you could replace the buzzer, maplins etc ...
  On 09/03/2014 at 13:42, WhackyWill said:
You can get the gearbox and diff oil and Molyslip as a kit from from Clarks.
Did mine as had same problem with 1st to 2nd, now perfect.
So PM Clark and get the correct fluids. :pmclark:
+1 ..although I got my Nissan gearbox oil & molyslip from Horsham Developments but same result. :yahoo:
Also sorted out changing from 5th to 6th gear for me which is smooth as you like now. B):D
