Stutopia Posted November 24, 2018 Share Posted November 24, 2018 So now the murky truth behind your secretive paymasters has all come out! This is as big, if not bigger, as the JFK cover up. 3 Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted November 24, 2018 Author Share Posted November 24, 2018 At least I haven't let slip that Gyeon have been sponsoring me years... 1 Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 21, 2018 Author Share Posted December 21, 2018 You may recall that as part of my... ahem, "pay off", I received so of this; Which, of course, I need to use. And by use, I mean test. And by test, I mean "test". Apparently. (I'm over it really...). Naturally this will be tested against Car Chem Revolt. First up, there are some differences between the two products - one comes with much fancier branding, the other is Revolt. Which means absolutely nothing to me or how the products work. Iron Detox comes with a new type of trigger spray head too - this is an on/off type jobbie with fixed nozzle and a larger trigger, whereas Revolt comes (or came, no idea if this is simply the new type used throughout the whole range now) with an adjustable spray head which allowed infinite adjustments. The other difference is that Iron Detox doesn't smell like Revolt. If you get a whiff of it you'd still recognise it as a fallout remover - and just to remind you that Revolt smells like the typical offensive rotting corpse odour, whilst Iron Detox has a very sweet scent that's much less offensive. The other difference is the consistency. Revolt seems to be much thicker, almost gel-like in consistency, whilst Iron Detox is thinner. Not watery, but not gel-like either. Those spray heads - Revolt type; Iron Detox type; So, usual routine; wheels washed with shampoo, water, several Wheel Woolies and detailing brushes. Rinsed with the pressure washer. Revolt applied to one wheel, Iron Detox applied to the other, allowed to dwell then rinsed with the pressure washer. Revolt applied to the other, Iron Detox applied to one wheel, allowed to dwell then rinsed. Which brings us to this; Revolt was first applied to the front wheel (Frankie for those interested...) and Iron Detox took the rear wheel (that one's Rita). Within about 1 minute Revolt looked like this; Meanwhile, Iron Detox did this; Yeah, not a lot going there at all. After a few more minutes, Revolt had done this; Most of this one was dripping off from the brake disc, but there's still plenty of other spots being picked up around that. Meanwhile Iron Detox had done this; again, the main vein is coming from the wheel weights but there's still other spots around that. But that was pretty much it. Nothing else was really picked up on the rear wheel. I mentioned earlier that Iron Detox is a thinner consistency, this did not appear to affect the cling time of the product (it was just as present at the top of the wheel as it was at the bottom) but given that it reacted with the weights and found some spots at the bottom of the barrel where all the product runs to, I'm not convinced at this point that the thinner consistency of Iron Detox isn't a factor. Anyway, both wheels were rinsed after around 5-6 minutes and then swapped. Iron Detox immediately did this upon application (the big purple puddle on the left is from the disc again); Meanwhile, Revolt immediately did this; Again that main vein on the left came from the weights; After a few more minutes, Iron Detox had found this (mainly from the disc); It also found one spot at the top of the wheel but that picture didn't come out. It was enough to ease my mind about the consistency being too thin as it was clearly working at the top of a vertical surface after a good few minutes. Meanwhile Revolt was doing this (mainly from the weights); So there you have it. Iron Detox found very little on Rita, Revolt found a little more afterwards. Revolt found a lot on Frankie, Iron Detox found a little more afterwards. Iron Detox then seems to be a good product; It smells nicer than Revolt. It has a fancy label on the bottle. Whilst the new spray head is simpler to use (literally just on or off) I'm not sure I like that over the adjustable version - the spray pattern it gives off will be perfect 9 times from 10, but there a times when I need to adjust the spray pattern due to wind; the finer the spray the easier product is carried away a wind (or breeze...). when used outside, this can easily become an issue. In terms of usage, I used about the same amount of both products, so I'm not sure I would choose Iron Detox over Revolt to be honest. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 21, 2018 Author Share Posted December 21, 2018 (edited) Part II - I came to the conclusion that there wasn't much fallout on Rita the rear wheel, fortunately I have one of those cars with four wheels so I attacked Floyd the front wheel with Iron Detox and Ryan the rear wheel with Revolt. All four wheels were pre-cleaned in the same method, as described above, in the correct order (Ryan, Floyd, Rita then Frankie, for those keeping count. Except when the car is parked the other way around, then it'd be Frankie, Rita, Floyd then Ryan. Obviously). So first up, before a whole minute had passed Iron Detox had done this; Most of that coming from the disc, naturally. Meanwhile Revolt had done this in a similar length of time on the rear wheel; Around 5 minutes, Iron Detox was looking like this; So fair to say Iron Detox found more on Floyd than it did on Rita first time round. Whilst that happened, Revolt looked like this; Floyd and Ryan were rinsed off with the pressure washer. Revolt moved on the front wheel and after a couple of minutes had found this; Iron Detox moved onto Ryan, which after a couple of minutes looked like this; Look past the main vein of purple from the wheel weights and there's some reaction towards the back of the barrel, but not a lot. After a few more minutes, Revolt was still doing this; Whilst Iron Detox had done; Nothing else at all. So I called it a day. I left them both dwelling whilst I started to packed up the products and the camera before rinsing. When I went back to rinse Floyd and Ryan I noticed that Revolt had more or less finished working with very little difference to above, whilst Iron Detox had actually done this (after 6+ minutes, give or take); So Iron Detox seems to take longer to work than Revolt. I don't think this has changed my mind about choosing Revolt over Iron Detox, but it might just have changed my mind about opting for Iron Detox over certain other products in the fallout remover category. Of course further testing is required to confirm this, but for now Revolt is still the one to beat for me. Also, here endeth the whole the-wheels-have-names thing. That's it, it's done. Promise. Edited December 21, 2018 by ilogikal1 1 Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 21, 2018 Author Share Posted December 21, 2018 Also tried Hydro Seal as well, but given that the car is wearing a coating and I washed with Bathe+ before topping up with Hydro Seal so no idea how well it protects, nor will I for some time. But it's very easy to use - it came with the new on/off type spray head which again will be fine most of the time but care needs to be taken when used in anything more than a stiff breeze. It's very similar to use to Gyeon Wetcoat, being a pre-mixed product it's just spray on to a wet surface and pressure wash off. You don't need a lot of product and accuracy isn't a problem when applying the product providing you ensure you're thorough with the pressure washer. Given that the only differentiator between these types of spray on rinse off products is durability and protection, neither of which I can possibly comment yet, there's not much else I can say about it really. Expect beading pictures later... Quote Link to comment Share on other sites More sharing options...
Ekona Posted December 21, 2018 Share Posted December 21, 2018 Another half-arsed “test” post as per usual. Honestly mate, if you’re not prepared to make an effort with these things then why even bother?! Sterling stuff as always, and more wheel naming in the future! 1 Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 21, 2018 Author Share Posted December 21, 2018 I know, my heart's just not in it any more. That's why it takes months between posts. @SuperStu just for a change, actual, natural, real beads for you. 1 Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 21, 2018 Author Share Posted December 21, 2018 1 Quote Link to comment Share on other sites More sharing options...
Umster Posted August 20, 2019 Share Posted August 20, 2019 Carchem Revolt, is it safe enough to use on car panels? Someone told me I could double up on it but not so sure. Google didn't offer me much conclusive help. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted August 20, 2019 Author Share Posted August 20, 2019 Good grief, I've not updated this thread at all this year!! 1 hour ago, Umster said: Carchem Revolt, is it safe enough to use on car panels? Someone told me I could double up on it but not so sure. Google didn't offer me much conclusive help. Yes, absolutely safe on panels - I use it all the time on paintwork as well. Just rinse off when (if) you notice it starting to dry out at all and you'll be fine. Just be absolutely certain not to let it bake on, that's the only time you'll have any issues. 1 Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 28, 2019 Author Share Posted December 28, 2019 So, quick recap, seeing as I've clearly not done any detailing at all since Last Chri... er, since the previous festive period (yep, totally avoided getting that somg stuck in my head again there!). One headlight was half coated with C5, the other half coated with Mohs back in May 2018, the other headlight was treated to some headlight restoration wipes which lasted all of about 12 minutes before failing, being polished (to clean it all off) and then coated with... something (I honestly don't remember!) in September 2018. Both headlights now need polishing again. Then I completed the fallout remover test, had a... "discussion" with Bilt Hamber about the results. At the time, my wheels were wearing 16 month old C5. That was, I think, the last time I threw anything considerable at them, protection wise. I'm fairly certain I will have topped up with various things (BSD, Wolf's Nano Wheel Coat, various other short term stuff) along the way, the last of which would have been December 2018 because I've done literally no cleaning of the car at all in 2019! Meanwhile, as far as I can tell (because I can't remember, I rely on this thread to tell me what I've done!) I last applied Gyeon CanCoat in May 2017 (back on page 22 forthose interested). The car's looking particularly clean and shiney in the pictures from May 2018 (page 24) so I suspect I've added something then - it looks polished and/or coated, but I've negelecte to mention that I've done anything to the paintwork. I don't think I did a full on coating, so it could be as simple as WetCoat but frankly, who knows! I did however mention in Decmber 2018 that I topped up the "coating" (possibly 19 month old CanCoat, possibly 7 month old something else!) with Bathe+ & Hydro Seal. Then I did nothing, for 372 days, or 53 weeks and 1 day, or 8,928(ish) hours. Which brings us from 21st December 2018 right up to today. Today I cleaned the car for the first time in 2019. Surprisingly enough, the Bathe+, Hydro Seal and possibly 31 month old CanCoat (that, I remind you, has a 6 month life span...) hasn't survived the year. Given this, the car was surprisingly clean still - I mean, it needed a wash but it wasn't filthy at all. Except the front wheels. They were filthy. So today was a cleaning day; I spent a good few hours on the wheels and tyres, including fall out removers (yes, plural, I've usning up left over stock. Doing a good job of it too, I've finished off 6 bottles of the stuff today), APC, foam, and proper contact wash. The wheels were tended to in a entirely random order (the correct order being Ryan, Floyd, Rita then Frankie, for those keeping track), namely Frankie, Rita, Ryan then Floyd for the first round, Floyd, Ryan Frankie then Rita for the second round and also Floyd, Ryan, Rita then Frankie for the tyres. Floyd and Frankie were filthy, in fact Frankie still isn't completely clean but I lost interest. Ryan and Rita's rubber took forever to get clean too. I don't know what those two get up to back there... Anyway, all wheels are (mostly) silver again and all tyres are quite black again. Surprising, Floyd is still showing patches of protection here and there. The rest of them however, are not. At all. I then moved onto the paintwork; snow foam with Car Chem Ultra Snow Foam (I'll come back to that), fallout remover (Iron Detox and Revolt when that ran out), APC (AutoSmart G101 for those interested) on all plastics, engine bay and boot shuts, then another foam with Super Suds Shampoo wash and a final rinse. Sadly time does not allow for much more than that this time round, so no clay, tar remover, paint cleanser, polish or anything else I would normally do at this stage. Instead the plan is to get something on the paintwork to see me through to Easter when I hope to have more time to do a full job on it. With that said, I still have no idea what I'm going to lay on the paintwork (or wheels) tomorrow - I'm torn between wanting to use CanCoat, Hydro Seal Hybrid and a number of waxes I bought and still haven't used at all yet. A comparison test may follow... Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 28, 2019 Author Share Posted December 28, 2019 In the meantime, I treated myself to this; Car Chem's terrific value litre bottles of 6 random products for £15 (+P&P). Considering most of there products on both the old & new site retail for £10+ for litre sizes, I couldn't resist. Now these mystery boxes are packed with 6 random products from Car Chem's entire stock, old & new. I suspect this also includes left overs/unclaimed stock from other brands that Car Chem supply too, largely because there are a number of products that Car Chem don't appear to offer directly (either in the current lineup or the originals lineup nor do I, as a long term customer, recall them offering directly previously either, however I am accutely aware that Car Chem are an industry supplier, hence the suspicion. There were, of course, also some products I was hoping for and some some I really didn't want to receive, but if given the price I thought it was well worth the risk. As mentioned, I used Ultra Snowfoam - not usual Car Chem fare, this is a clear and particularly thick, gel-like consistency more akin to shampoo than usual red, watery CC snow foam. It has a scent that I can't place either, again akin to that of a shampoo I think. It does say on the bottle that it can be used as either snow foam or shampoo in the bucket, and diluted 1:200. I applied the very scientific "chuck some in the bottle (which already had some usual CC snow foam in - about 200ml maybe) until I'm bored of waiting for it to pour" method. I estimate probably another 200ml (ish) of Ultra, then topped up with warm water (about 400ml of water), thrown at the car through my oldest foam lance turned ll the way to - then back half a turn. It produces a thicker foam than "usual CC" (as I've now dubbed it), but nowhere near the thickest that I've used (that's a good thing!). Its about as thick as I'd want my snow foam to be, any thicker and it won't slide off the panel well enough to actually take any dirt with it. As a result it offered good cling time and it still cleaned pretty well. That said, the run off is still sat on the drive now (about 3 hours later). I'd quite happily use it again but I definitely don't have the patience for pouring it - being a very thick consistency, it's like pouring treacle. That said, it's in a litre bottle so I could probably just stick my foam lance on the bottle and use it neat. I might try that next time. Also in my mystery box of self-giftiness, I received; Which I probably won't use, although it does say it can be used on interior trim & dash so I'll at least give it a try on the interior plastics. Which I'll probably use on door & boot shuts, but again that's about it. This also doesn't appear to be usual Car Chem fare as their waterless wash & wax is green. Which is a delightful product that has previously removed 14 years worth of dog from a relatives car with a single use. I will probably have to go looking for reasons to use to use a whole litre of it, but I do like Odour Eliminator. Some purple Revolt. I don't know much about this product, but I've heard it's okay. Actually no idea why it's purple but I'll definitely take it anyway. What can only de described as a life time supply of glass sealant. Okay, it's not a ceramic coating, but I'm still working my way through the 100ml of Ultra Glass Sealant V2 I bought about 6 years ago! This can be layered for greater durability of 4-6months, but it's so easy to apply it's not a problem to top up fortnightly/monthly anyway. So I may never buy a glass sealant or coating ever again now. Also as a bonus, I also got; So yeah, not bad for less than £20 delivered to my door really. Especially as litre of Glass Sealant alone would set you back £70, snowfoam is £12 per litre, waterless wax & wax is £16, QD doesn't appear to exist in any form, Odour Eliminator is £11.50 (£12 for the original version), Revolt is £14 and HydroCoat Hybrid is... okay, that's currently free with the code in fairness. Still, even ignoring Glass Sealant, £53.50 + a product that doesn't exist + Glass Sealant for about £18 will do nicely thank-you-very-much! Reviews may follow. I'm not promising any time soon though! 2 Quote Link to comment Share on other sites More sharing options...
LRF4N Posted December 28, 2019 Share Posted December 28, 2019 Have you had any experience with shine armor? I see it on instagram every few days Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 29, 2019 Author Share Posted December 29, 2019 2 hours ago, LRF4N said: Have you had any experience with shine armor? I see it on instagram every few days Can’t say that I have, never seen their products anywhere before let alone used them I’m afraid. Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted December 29, 2019 Share Posted December 29, 2019 That's one hell of a haul for the money! If i managed to bag that lot, my family would be recieving detailing samples for Christmas for many a year to come Quote Link to comment Share on other sites More sharing options...
scobie140 Posted December 29, 2019 Share Posted December 29, 2019 a year without washing your car is a good effort Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 29, 2019 Author Share Posted December 29, 2019 I have a plan forming. It's a plan that involves no less than 6 LSP's (maybe 7), 3 different cominations (maybe more) and upto 3 different brands... or 4 if you count the different Car Chem brands as different brands. I just need to figure out what's going where. The plan is Car Chem Pre-Wax Cleaner all over - because waterspots. An area of Car Chem Carnauba Glaze Polish - which in theory should give 2 months protection on it's own. An area of Car Chem PTFE Polish Sealant - which in theory should give 3-4 months protection in it's own. An area of Car Chem HydroCoat - this will be physically applied (rather than diluted & sprayed on a wet car). An area of Car Chem Carnauba Glaze Polish topped with Car Chem HydroCoat - because they play well together and should, in theory, provide more durability than separately, as I'm applying each separately it seems reasonable to test this. An area of Car Chem PTFE Polish Sealant topped with Car Chem HydroCoat - because that ^. An area of Car Chem OB Glaze - because I have it and I haven't used it anywhere near enough. Plus UV brightener, so I can actually see when this one has fallen off with a UV torch. And who does't like gimmicks?! An area of HydroCoat Hybrid - because it's new so I have to. An area of Poorboys Natty's Black Paste Wax - because I have it but haven't used it, so principals. This may even top something else to see how well wax bonds to it. The rest might be topped with Gyeon CanCoat - because winter. I'm thinking HydroCoat, HydroCoat Hybrid and OB Glaze on the bonnet (which will be wiped down with Gyeon Prep after the Pre-Wax Cleaner, so will be applied to bare paint). The boot will be half PTFE Polish Sealant topped with HydroCoat and half Carnauba Glaze topped with HydrocCoat. The horizontal panels will most likely have CanCoat applied. The roof might be some cobination of CanCoat topped with/or Poorboys Black. Maybe. Quote Link to comment Share on other sites More sharing options...
LRF4N Posted December 29, 2019 Share Posted December 29, 2019 19 hours ago, ilogikal1 said: Can’t say that I have, never seen their products anywhere before let alone used them I’m afraid. Have a look at their ads for fortify. It’s apparently a waterless wash that’s more effective than wax and ceramic coatings. They do no prep, not even a wash before applying Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 29, 2019 Author Share Posted December 29, 2019 2 hours ago, LRF4N said: Have a look at their ads for fortify. It’s apparently a waterless wash that’s more effective than wax and ceramic coatings. They do no prep, not even a wash before applying Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted December 31, 2019 Author Share Posted December 31, 2019 Firstly, just to acknowledge that I've sort of done a Carnauba Glaze, PTFE Polishing Sealant, Hydro Coat thing before (back on page 11). However I didn't really conclude that and I'm doing it again anyway. So there. So some things have occured. To start with, the entire car has been CC Pre-Wax Cleaner...ed (?), and despite pulling out a lot of dirt from the paintwork, it is no good for removing waterspots - in fairness it was a long shot but I had hoped that the chemical cleaners would help. It did not. Applied by hand with a microfibre pad everywhere except the bonnet which I attacked with a black CG Hex Logic pad on the DA - it's a finishing pad, so doesn't offer any cut either. I then ended up actually polishing the bonnet with Scholl S30+ on a green LC Contant Pressure pad, just a couple of quick passes so not a perfect finish but rather just enough to give bare paint. I also gave the headlights a quick pass with the polisher whilst I was there. The bonnet was then given a wipe down with Gyeon Prep. The boot was then taped up for Car Chem Carnauba Glaze. This was applied to the passenger side from the wing mirror, up the A-piller trim and down about two thirds of the boot; After than was applied, the boot was re-taped up and PTFE Polishing Sealant was applied to the driver side from the wing mirror back to two thirds of the boot; After that was applied, a coat of Hydro Coat was applied from A-pillar, across the boot to the other A-piller. This was physically applied with a cotton make-up pad, with each section given between 5-6 minutes to cure before being buffed off. I really do like using this stuff it's so easy to spread over a decent area with minimal effort and get a thin, even coverage, it's also really easy to buff off and leave a great finish. The roof and the A-pillar trims were then given a layer of Pooboys Natty's Black Wax The bonnet is currently wearing HydroCoat on the driver's side, HycroCot Hybrid in the middle and Ob Glae on the passenger side; Each was applied with it's own microfibre pad and buffed with it's own microfibre cloth to avoid contamination, and following the instructions from the Car Chem website (and bottle labels), namely; HydroCoat was spread thinly over the panel using overlapping strokes, allowed 5 minutes to cure, then buffed off. As mentioned, this is delightful to use whether it's applied woth a cotton pad or a microfibre pad - even if it's over applied, because it's a liquid, it's really easy to spread further. Being an old-school Car Chem product, it doesn't have any fancy colouring, fancy scents or fancy labels, so it's just a cloudy liquid that smells solventy with a clear label. HydroCoat Hybrid was significanly overapplied - when the instructions say a small amount, they mean a tiny amount (I'm fairly confident in saying that one single spray from the sample bottle could have done the entire bonnet. I missed the words "small amount" and, being a new bottle, got about 2.5 sprays on the pad... for a third of the bonnet!). It was spread over the panel using a cross-hatch pattern and as thinly as I could manage, however in hindsight it wasn't that thinly at all really. It was left for 5 minutes to cure... which it didn't, so I buffed (read, re-spread it) and gave it another 5 minutes before rebuffing. Despite over-applying, the only downside is that it didn't cure in the 5 miuntes and the panel was still wet. It was still really easy to buff (and re-spread). Now, this is a new-school Car Chem product, it has a fancy colouring (blue), fancy scent ("ice cool" - no idea what that is in real life, but it does smell delightful!) and a the fancy new labelling; which, if it included such things (being a smaple size, that's limited), makes it much easier to read the information the label. I'll come back to that. OB Glaze was spread over the panel in overlapping strokes, allowed to cure for 15 minutes then buffed off, per the instructions. This was also really easy to apply, it spreads forever and day and you can easily see where you've applied. However buffing was a different matter - I feel that 15 minutes is too long as I encountered som resistance to buffing. It's like a partucularly tough wax that's been over applied (and perhaps that was more the issue, that I over applied) where you have to "break through" with the first swipe of the cloth before being able to buff properly. To the naked eye it looks okay (not great, certainly not quite streak-free) but under the UV torch it looks horrendous with streaks everywhere. This is just the first coat though, and I've planning on doing at least one more (again, I'll come back to that) so hopefully another coat will even it out. We'll see. Anyway, being an old-school Car Chem product, this also has no fancy colours (other than the UV brighteners... does that could as a colour?), no fancy scents and a clear label. Being a (reasonably) clear liquid (it does have a violet tint to it around the edges in daylight, almost like it's reacting to the UV rays or something!) in a clear bottle with a clear label makes reading the label a little tricky really. It also just smells of solvents. To recap, currently; The passenger wing mirror has 1 coat of Carnauba Glaze. The driver wing mirror has 1 coat of PTFE Polishing Sealant. The roof has 1 coat of Poorboys Black wax. The passenger side third of the boot lid has 1 coat of Carnauba Glaze topped with 1 coat of HydroCoat. The driver side third of the boot lid has 1 coat of PTFE Sealant topped with 1 coat of HydroCoat. The middle third of the boot lid has 1 coat of Carnauba Glaze topped with 1 coat of PTFE Sealant topped with 1 coat of HydroCoat. The passenger A-pillar trim has 1 coat of Carnauba Glaze topped with 1 coat of HydroCoat topped with 1 coat of Natty's Black wax. The driver A-pillar trim has 1 coat of PTFE Selant topped with 1 coat of HydroCoat topped with 1 coat of Natty's Black wax. The passenger third of the bonnet has 1 coat of OB Glaze. The middle third of the bonnet has 1 coat of HydroCoat Hybrid. The driver third of the bonnet has 1 coat of HydroCoat. The passenger headlight lens has 1 coat of OB Glaze. The driver headlight lens has 3 coats of GTechniq G1 (because I found I had some, so why not?!) Keeping up with all that? Oh good. Per the instructions, Hybrid can layered after 1 hour. There's no mention of layering OB Glaze, but I understand it's based on Nano Shell which can be layered after 90 minutes (it does need 12 hours to cure before it can get wet though). HydroCoat however requires a mere 8 hours between layers. Therefore the plan is to do another layer later tonight/early tomorrow morning and them maybe a third layer of each tomorrow. Nano Shell does state to only apply a maximum of 2-3 layers, so I may stop at 2 layers but then I may not. I think it'll depend entirely on how OB Glaze reacts to the 2nd layer more than anything. Also, if you're paying attention you may have noticed I've missed a few panels. I'm still undecided what's going on the rest of the car. I also need ot start building up layers of Glass Sealant... Also apologes for the pictures, I seem to have left my actual camera not where I am so these were taken with a phone. Unfortunately that phone is an iPhone, so the pictures are not great. 3 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted December 31, 2019 Share Posted December 31, 2019 A new test for the 20s, alright! Quote Link to comment Share on other sites More sharing options...
G1en Posted December 31, 2019 Share Posted December 31, 2019 Great stuff just how “long” is this test planned to last for. I simply ask for the “elder statesmen” of the forum that sadly may not be with us to reach its conclusion and thus can decide whether to carry on Reading past this point. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted January 1, 2020 Author Share Posted January 1, 2020 Who knows.... In theory, unless anything chages between now and then, I'm planning on doing a proper detail when I have more time in April. However the bonnet should be good for a year now. That said, I've still got plenty of products left over, so I may never stop "testing". Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted January 1, 2020 Author Share Posted January 1, 2020 Also, subsequent layers have been applied all round. Some things I've learnt - the issues with the first layer of OB Glaze was very much due to (massive) over application. When applied properly it's a breeze to work with. HydroCoat Hybrid is also much easier to apply properly with coating applicator and suede cloth. Top tips; Use a coating applicator block with a suede microfibre to apply any liquid LSP, it's a lot easier to get a thin layer - can you tell which one I used for OB Glaze? Apply OB Glaze in the dark under UV lighting, it'll revelutionise what you think you know about applying an even layer because you can very much see high spots; Also, OB Glaze is very difficult to photograph well with a cheap UV torch on a blue car however in person it's very noticable. on the photo above, the bonnet section, headlight and the angle of the bumper around the headlight are all coated, whilst the vertical sections of the bumper (across the bottom and the left hand side below the bonnet gap) are not - basically everything you can see is, everything you can't isn't! As a side note, if OB Glaze leaks, it's very easy to trace where it's leaking from... Okay, that's enough UV photos (for now anyway). The car is now wearing: The passenger wing mirror has 1 coat of Carnauba Glaze. The driver wing mirror has 1 coat of PTFE Polishing Sealant. The roof has 2 coats of Poorboys Black wax. The passenger side third of the boot lid has 1 coat of Carnauba Glaze topped with 2 coats of HydroCoat. The driver side third of the boot lid has 1 coat of PTFE Sealant topped with 2 coats of HydroCoat. The middle third of the boot lid has 1 coat of Carnauba Glaze topped with 1 coat of PTFE Sealant topped with 2 coats of HydroCoat. The passenger A-pillar trim has 1 coat of Carnauba Glaze topped with 1 coat of HydroCoat topped with 1 coat of Natty's Black wax topped with 1 coat of HydroCoat (because I forgot I'd waxed that...). The driver A-pillar trim has 1 coat of PTFE Selant topped with 1 coat of HydroCoat topped with 1 coat of Natty's Black wax topped with 1 coat of HydroCoat (because I forgot I'd waxed that too...). The passenger third of the bonnet has 2 coats of OB Glaze. The middle third of the bonnet has 2 coats of HydroCoat Hybrid. The driver third of the bonnet has 2 coats of HydroCoat. The passenger headlight lens has 3 coats of OB Glaze. The driver headlight lens has 3 coats of GTechniq G1. Both front wings, doors, rear quarters, rear bumper and some sections of the front bumper is all wearing 1 coat of CanCoat - just to note none of this was wiped down before CanCoat was applied, hence much of that has Pre-Wax Cleaner under it but some has Scholl S30+ under it instead. The trim is wearing HubiKote HubiTrim. Most of which is still curing, which will take 12 hours, but I still need to do the glass, wheels and tyres, so expect beading soon. I'm also expecting a funky new toy from Direct Hoses to arrive this week... 3 Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted January 3, 2020 Author Share Posted January 3, 2020 So then; This looks very much like Ultra Glass Sealant V2 - i.e. a cloudy liquid. This smells very much like Ultra Glass Sealant V2 - i.e. solvents. The instructions for this are remarkably similar to Ultra Glass Sealant V2 - i.e. apply with a microfibre cloth, ensuring a good even coerage, buff with a different microfibre cloth. Take a clean cloth and go over all the surfaces one last time, buffing in circles rubbing off the last residue. (Stubborn marks can be removed by damping a microfiber and wiping over). By way of prep, I polished all exterior glass (and the inside of the driver's window) with GTechniq G4, buffed using G6 to dampen the cloth. I've now applied multiple coats of this - it suggests on the bottle to top up once a week for 4 weeks to get 6 months protection. I'm likely to reapply in 4 months, so I did various coats over 24 hours instead. This allowed me achance to test out various different application methods so; 1st layer; sprayed onto a microfibre cloth, spread over one window at a time (front & rear screens done a whole rather than in sections, subsequently between 0-2 minutes curing time), buffed immediately. As with Ultra Glass Sealant V2, it spread really easily and a little went a very long way, it was also incredibly easy to buff even with no curing time. I then waited (well, did something else for) a couple of hours before applying the 2nd layer, which was applied in the same way as Ultra Glass Sealant V2 is; namely sprayed onto a microfibre cloth, spread over all windows, allowed to cure for up to 15 minutes, then the residue is buffed off. Except it didn't cure. Instead it flashed off, akin to a glass cleaner, within a minute. Still, I left it 15 minutes before buffing. So I immediately applied a 3rd layer to the rear screen, also applied with a microfibre cloth and wiped over the whole screen. The driver side half was buffed after a few minutes, the passnger side was not and simply flashed off. This was left ~14hours to cure. In the meantime a thought occured to me; Car Chem don't sell Ultra Glass Sealant V2 under the new branding (it's still available under the Originals branding though), instead they now sell Clear View Glass Cleaner which is a cleaner and sealant in one. Can you see where I'm going with this? Well, that's a blue liquid and this is not. BUT! Car Chem, when announcing the Mystery Boxes, did state that products could include surplus prototypes as well as old & new. So, it's possible that this is either a prototype of Clear View, a variation of Ultra Glass Sealant V2 (or both), or something else entirely. Putting two (this flashing like a glass cleaner) and two (Clear View being a cleaner sealant) together, I came up with trying it on the shower door. I can confirm that this glass sealant does remove reasonably fresh water spots and soap residue from glass shower doors. I can also confirm that this glass sealant does work better when it's buffed (I applied to half the shower door but only buffed half that area after a couple of minutes). I cannot confirm that this is any sort of variant to either Ultra Glass Sealant V2 or Clear View Glass Cleaner. The following morning, I applied a third layer to the front screen; wiping on with a microfibre cloth and buffing after a few minutes. And then for good measure, I applied a fourth layer to both front & rear screens in the same way, after cleaning the interior glass (with G6, for those interested) - so maybe between 20-30 minutes to cure between layers 3 & 4 on the front. A few hours later I rebuffed all exterior glass to make sure I've removed all streaks. At no point have I noticed any residue left to buff with this, however where it isn't buffed anyway there's noticeable streaking (more noticeable when the surface has condensation on - or in the case of the shower door, when it's steamed up), but it seems so far that this is really easy to buff out a good few hours later - currently at 12 and counting on another test section of the shower! Oh, and at some point during all that, I'd used this much of my litre: That's about 2ml. Since then, having done 4 layers on the front & rear screen, 2 layers on each side window & wing mirror glass on the Z along with the shower door (inside & out), I've used maybe another 7-8ml. Assuming I over apply and use 6ml to do four layers on the Z, it'll last me 166 applications. And assuming 6 months per application, this bottle will last me up 83 years. Even if each application only lasts 2 months, the bottle will still see me through the next 27 years. So, let's find out how long this bottle is going to last me then.... 1 Quote Link to comment Share on other sites More sharing options...
