leebottrill Posted March 5, 2014 Share Posted March 5, 2014 I've noticed that a couple of times now my roof will stop retracting in the last stage on the process! I close it and do it again and its fine, just kind of clicked back into place! Just Spoken to the Nissan lady and she said that's quite common and nothing to worry about! Anyone else had this? Quote Link to comment Share on other sites More sharing options...
SteveM Posted March 5, 2014 Share Posted March 5, 2014 (edited) you mean when you are opening it or closing it? if you mean you are opening it and it gets almost open then stops its common and its down to the cold weather. the roof material is quite stiff and although the manual says it will operate down to 5 degrees in reality thats more like 10 degrees! unless you can park the car in a sunny spot on a cold winters day to warm the roof or have the heaters on full bore in the car for a while to heat the roof it will not fully open in cold weather and you can damage the roof by trying to force it. if its stopping when you are trying to close it thats a different one and not one i have heard of Edited March 5, 2014 by SteveM Quote Link to comment Share on other sites More sharing options...
leebottrill Posted March 5, 2014 Author Share Posted March 5, 2014 Hi Steve. Its when I am opening the roof and yes its at the final stages! Just before the last bit flips over the top! Yes its been 3 and 4 degrees when the problems have happened! So I don't need to panic just yet, but warm the car up? Quote Link to comment Share on other sites More sharing options...
SteveM Posted March 5, 2014 Share Posted March 5, 2014 no need to panic then.... like i said either park the car in the sun for a bit to warm the roof or have the heaters on in the car for a while to warm it from the inside out... its a pain sometimes that on nice crisp cold sunny days you cant get the roof down but its just the way it is with the roof material that Nissan used. Quote Link to comment Share on other sites More sharing options...
leebottrill Posted March 5, 2014 Author Share Posted March 5, 2014 Did you say sun? Haha have you been to Cornwall? :-D 1 Quote Link to comment Share on other sites More sharing options...
zxrob Posted March 5, 2014 Share Posted March 5, 2014 Mine does the same in the cold weather The owners manual advises 5deg for operation Rob Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted March 5, 2014 Share Posted March 5, 2014 Yep perfectly normal. You can reach back and give it a bit of a shove, or close it slightly then reopen. Id be wary of trying to force it too much. As others have said, I found it was down to the cold weather. The stiffer roof material seemed to strain the motors a bit more. It was fine in the summer. 2 Quote Link to comment Share on other sites More sharing options...
Keyser Posted March 5, 2014 Share Posted March 5, 2014 Did you say sun? Haha have you been to Cornwall? :-D No I haven't got a boat 1 Quote Link to comment Share on other sites More sharing options...
hensh65 Posted March 5, 2014 Share Posted March 5, 2014 Why would you want the roof down under 5 degrees Quote Link to comment Share on other sites More sharing options...
Digsy Posted March 5, 2014 Share Posted March 5, 2014 Slightly off topic but how are the roofs holding up now that the oldest cars are pretty much 10 years old? Quote Link to comment Share on other sites More sharing options...
SteveM Posted March 5, 2014 Share Posted March 5, 2014 Why would you want the roof down under 5 degrees Because on a cold crisp sunny day with a jacket and wooly hat on it feels great to be out with the roof down Quote Link to comment Share on other sites More sharing options...
Keyser Posted March 5, 2014 Share Posted March 5, 2014 Why would you want the roof down under 5 degrees Because on a cold crisp sunny day with a jacket and wooly hat on it feels great to be out with the roof down Well that and the fact that like Wil370 Steve can look over the windscreen while driving a roadster with the roof down 3 Quote Link to comment Share on other sites More sharing options...
leebottrill Posted March 5, 2014 Author Share Posted March 5, 2014 Yea dam right! Nice crisp morning (like today) its great! Makes the drive to work bareable! (If the roof worked) haha well I guess I'll stop panicking for a sec! Quote Link to comment Share on other sites More sharing options...
Ridz Posted March 5, 2014 Share Posted March 5, 2014 Driving the roadster on cool, sunny mornings, nothing better, especially if you have a quality exhaust fitted and you can hear that V6! Like all the other comments, the roof is reluctance to close at low temps. Best remedy, I have found, is to park in a sunny spot, give it 15 minutes for the solar UV to heat up the black canvas hood, and then it will close, no problem! Tip: if the canvas roof flexes at the last section, nearest the boot, when you push it slightly, you are good to go! And then enjoy your Zed! Quote Link to comment Share on other sites More sharing options...
Meeerrrk Posted March 5, 2014 Share Posted March 5, 2014 Driving the roadster on cool, sunny mornings, nothing better, especially if you have a quality exhaust fitted and you can hear that V6! Like all the other comments, the roof is reluctance to close at low temps. Best remedy, I have found, is to park in a sunny spot, give it 15 minutes for the solar UV to heat up the black canvas hood, and then it will close, no problem! Tip: if the canvas roof flexes at the last section, nearest the boot, when you push it slightly, you are good to go! And then enjoy your Zed! Or get a mohair roof fitted and never worry again! Agreed its due to cold, bit of a nightmare really but worth it to hear the sound! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
leebottrill Posted March 6, 2014 Author Share Posted March 6, 2014 Well I'm happy as long as I know the roof isn't broken! Only had the car 1 week so was a bit of a worry! This forum rocks Quote Link to comment Share on other sites More sharing options...
leebottrill Posted March 6, 2014 Author Share Posted March 6, 2014 Ohh as far a keeping the roof well lubed, what and where should I apply the spray? I'm assuming it would be some kind of silicone spray? Also to keep the hood in good condition is there a good spray you can apply? Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted March 6, 2014 Share Posted March 6, 2014 (edited) Ohh as far a keeping the roof well lubed, what and where should I apply the spray? I'm assuming it would be some kind of silicone spray? Also to keep the hood in good condition is there a good spray you can apply? I used to treat my roof every 4 months with some AutoGlym cabriolet roof kit. There was a special cleaner solution you scrubbed into it first, let it dry then spray on this sealant stuff which waterproofed and conditioned the roof. Kept my roof looking brand spanking new. As for roof down in winter. I used to love it. Made that boring journey home from work much better, gazing up at the stars etc. You stick the heaters on and they are pretty good so your driving along in a nice bubble of warm air. Edited March 6, 2014 by rabbitstew Quote Link to comment Share on other sites More sharing options...
Meeerrrk Posted March 6, 2014 Share Posted March 6, 2014 The autoglym is the best I've found over the years. Makes the roof bead up nicely Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted March 12, 2014 Share Posted March 12, 2014 +1 for autoglym enjoy your roof down motoring. i hear its going to be a hot summer :-) Quote Link to comment Share on other sites More sharing options...
Ridz Posted March 12, 2014 Share Posted March 12, 2014 Agree with the Autoglym roof treatment, have used it on my 2006 roadster with good results. I understand that Renovo is a superior product, but haven't used it yet. Sorry if that's off topic, and should maybe in the detailing section. Been out the last 2 days in the great weather with the top down and enjoying that great V6 sound!!! Quote Link to comment Share on other sites More sharing options...
zxrob Posted March 13, 2014 Share Posted March 13, 2014 I have some renovo ready to use on the roof, just aint got around to doing it yet Rob Quote Link to comment Share on other sites More sharing options...
leebottrill Posted March 13, 2014 Author Share Posted March 13, 2014 What's the autoglym roof stuff called? Quote Link to comment Share on other sites More sharing options...
Will370z Posted March 13, 2014 Share Posted March 13, 2014 Its in halfords, a duel pack with 1 spray of cleaner and 1 thats a protector. You also get a white tough sponge to work the products in. Its £19, bought a replacement last weekend since they are doing a 3 for 2 offer atm 2 Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted March 13, 2014 Share Posted March 13, 2014 scared to use Renovo as I hear its a bit of a mare to get off of paintwork. Quote Link to comment Share on other sites More sharing options...
