DiscoPotatoes Posted March 2, 2014 Share Posted March 2, 2014 Hi I'm hoping someone can shed some light, I checked the oil this morning and it was about half full on the dipstick, so topped it up. When I started it it sounded like the bearing were dry and it made an awful racket, so i turned it off and tried again, the same thing happened but to a slightly lesser extent, so turned it off and restarted, the rattling went away after a couple of seconds and was good as gold for the rest of the day. Anyone else had this? I thought about using lucas oil stabiliser which is incredible stuff, I use it in all my other vehicles (engines/ gearboxes/ diffs)but they are high flow low pressure systems. The stuff is really sticky and eliminates dry starts, but I'm sure it thickens the oil a bit so not sure if its ok to put it in an engine that likes thin oil. Cheers Disco Quote Link to comment Share on other sites More sharing options...
AK350Z Posted March 2, 2014 Share Posted March 2, 2014 Sure it wasn't the clutch? Most are quite rattly. Quote Link to comment Share on other sites More sharing options...
DiscoPotatoes Posted March 2, 2014 Author Share Posted March 2, 2014 Sure it wasn't the clutch? Most are quite rattly. No it wasn't defo oil starvation Quote Link to comment Share on other sites More sharing options...
HAMLNJ Posted March 2, 2014 Share Posted March 2, 2014 Mine does it, just cams slightly out of line. Nothing to much to worry about. Quote Link to comment Share on other sites More sharing options...
HAMLNJ Posted March 2, 2014 Share Posted March 2, 2014 Tappet out I mean Quote Link to comment Share on other sites More sharing options...
mattross1313 Posted March 3, 2014 Share Posted March 3, 2014 I wouldnt say mine had an 'awful racket', but on start up there was a rattle for 1-3 seconds. I think it was caused by the timing chain being slightly loose, and the few seconds of rattle are before the tensioners come up to pressure. Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted March 3, 2014 Share Posted March 3, 2014 (edited) Isn't this the hydraulic tappets, they drain and it takes a second or so for them to fill and pressure up Obviously not helped by the longer a car is left standing and low oil The culprit of a noisy bearing is often the alternator, I certainly wouldn't be adding an oil additive on the description you gave Hth Paul Edited March 3, 2014 by GIXXERUK Quote Link to comment Share on other sites More sharing options...
HAMLNJ Posted March 3, 2014 Share Posted March 3, 2014 I'd be interested to know if anyone has had their tappet adjusted. It annoys me when mine does it. If it's the thing chain can this be corrected eaiselly ? Quote Link to comment Share on other sites More sharing options...
